scanner fo codes
Old Apr 6, 2000 | 08:15 PM
videoman's Avatar
Lightbulb scanner fo codes
I need an inexpensive scanner for the 1996-2000 EEC V ORB II computer 1997 F150. It's the late model nobody handles ie: PEPBOYS, AUTO ZONE, DISCOUNT AUTO. Iam tired of getting ripped off at my local dealer 3 times to the tune of $85.00 each time to check the 3 codes in 4 weeks for check engine light. First they replaced the idle solonoid, the the oxygren sensor RT side, the gas return canister,at my expense. Now the lights back on for the 4th time. Strange enough my truck runs fine through all this.
I REALLY NEED A SCANNER since my truck has 37,800 miles on it (sorry out of warranty.)
Can any one HELP ME??????
1997 F150 4.2L,auto.3.55 gears,shift kit, AIM Phantom Fiberglass Frt.
End, Recessed Hd.Lights behind billett grilles, Fiberglass Cobra Hood 4"-6'AIM Drop kit,etc.
Old Apr 6, 2000 | 09:35 PM
R Bess's Avatar
Post
There no inexpensive scanner for this, they're all over $300.
A. Be sure you always have the gas cap on when your truck is running.. This will cause the light to go on (the computer checks for pressure in the gas tank, and will signal the light if there is pressure loss). so, if you fill your truck up with fuel with the engine running, thats a no-no..
b. If the truck is running fine, good mpg, smooth engine, then run it a few days with the light on, and see if it goes off..
Your not damaging anything..
Old Apr 9, 2000 | 03:06 AM
redlariet's Avatar
Post
Summit Racing has an Actron/sunpro #cp9035 for $140.
Old Apr 11, 2000 | 08:33 PM
Bill Bateman's Avatar
Post
I use and Autotap code scanner. I think I paid $245 but forget the actual cost. It consist of an interface cable to plug your computer into the port on your vehicle and software to run on the pc. Works pretty good.
98 SC/XL/4.2/5 speed/3.08/MoonLight Blue Metalic/Mobil One Synthetic/235.70S.16 Michelin XC LT4/AR-136 Wheels/Chrome Nerf Bars/Bug Shield/Aluminum Tool Box/K&N/Superchip/NOS maybe.
DAMN FLEXING DOOR CRACK!
Ford Engineering, reinforce the curve in the door! The cracks will stop.
Old Apr 11, 2000 | 08:48 PM
redlariet's Avatar
Post
Ordered the actron from Summit Sunday morning-got it by UPS this afternoon. Plugged in the Lariet & it works ok.
