Coil packs? 4.6 , 5.4?
Old Nov 21, 2001 | 03:00 PM
Josh Brown's Avatar
I have a 99 S/C 4x4, 4.6, K&N intake kit, Flowmaster exhaust. I recently replaced spark plugs and wires#@%$. The coil packs are the things on the front of the engine that the plug wires go to right? My friend has a 01 with a 5.4, He doesn't have the coil packs, I thought the engines were more similar. I am confused. M truck seems to be quicker on the freeway than his, his is stock. Just thought I'd share that.
Old Nov 21, 2001 | 03:06 PM
dnale's Avatar
you don't have coil packs
If you have plug wires, you definitely don't have coil packs. Coil packs sit directly over the plug. You are seeing the distributor block.
Old Nov 21, 2001 | 03:53 PM
Josh Brown's Avatar
Do all 4.6 vhave the things I have? If not when did they change?
Old Nov 21, 2001 | 04:15 PM
JMC's Avatar
JMC
25 Year Member
Josh,
FYI all F-150 5.4 engines use the coil on plug (COP) ignition. All 1997-99 4.6 engines use the coil pack with plug wires, and all 2000 + 4.6 engines use the COP.
Regards
Jean Marc Chartier
Old Nov 23, 2001 | 12:39 PM
Pickup Man's Avatar
Yes, the coil packs are the things that the plug wires connect to on the front sides of your engine. They usually last about 100,000 miles. Glad to hear that you're quicker than a 5.4.
Old Dec 18, 2001 | 03:24 PM
JHimes's Avatar
Last 100K in theory!
I had to have 2 replaced under warranty with less then 1K miles! It ran rough due to the bad coil.
Now with almost 10K miles, no more coil problems.
2001 Screw 4.6
Old Dec 18, 2001 | 07:53 PM
Boss Ross's Avatar
Quote==== "If you have plug wires, you definitely don't have coil packs. Coil packs sit directly over the plug. You are seeing the distributor block."
We'll think before you drink.
The 4.6 wires do run into a coil pack. The 5.4 has a totally different setup. The 5.4 has 8 seperate coil packs that mont directly on top of the spark plugs and run through a series of connectors. :o
Old Dec 26, 2001 | 10:34 PM
Wino's Avatar
jmc is right on this one. a truck with plug wire's has coil pack's. and coil on plug is just that, one coil per plug. coil pack. a unit with four plug wire's going to it. with two coil's in side that little black box. one coil for two cyl's. it fire's on compression stroke and exhaust on the oposing cyl. at the same time. with the coil on plug sys. it is a better ignition sys. and can use a smaller coil. with out heat build up. it does not keep the coil on all of the time. it just turn's it on just before it need's it. and it does it very fast. but that keep's the heat down in the coil. they both work about the same. just no dang plug wire's on the one.
Old Dec 27, 2001 | 10:34 AM
MCEXP's Avatar
I had 6 "engine coils" replaced, over a 3 year period. Ford said they had a known problem and gave me an extended warranty due to the problem. Anyone else have this problem. When the coil went bad the engine would vibrate, and idle real low, also at speeds of around 45 it would shake violently, and miss horribly.
