Truck Dies???????????
Hello
i have a 97 f150 and the last few months i have noticed that from time to time(usally when iam at the lights. the truck just dies (does not stall) or if i turn a corner the wheel locks up and i look down and the truck is dead i have to start it again to go around the corner.
i spoke to a few other people i know that have the same year and truck (97 ext cab bed and manual trans) and they have the same problem
is this a known problem? can i fix it?
many thanks
steve
many thanks
steve
I have a 99 F-150 with a 4.6L that had a problem with the engine almost dying but would always come back to normal rpms. The dealer could not find a problem and it would not repeat for the dealer(they said). It was dangerous when this happened if you were turning a corner. What I did that fixed mine, at least for now, was disconnect the battery for about an hour the reconnect and go out and drive the !#$% out of it. It hasn't happened again now for abot 5000 miles. Good Luck.
LTDC
99 F-150, ext cab, 4.6L, 3.55 gears, limited slip, manual trans. catbac exhaust
LTDC
Does it start right up when you re-start it? This sounds like a problem I had with my 89 5.0 Mustang. Dealer said it was a weak fuel pump. They replaced it for $300. Did it again about 3 weeks later. Took it to my hometown mechanic. He found it. The computer ground wire was loose and sending the wrong info to the engine. Never had a problem again!
[This message has been edited by J.J. Middleton (edited 01-11-2000).]
