how to take head off 1999 ford f150 because of socket stuck on plug.
Old 08-25-2017, 04:48 PM
ak1164's Avatar
The spark plug socket is stuck on the plug what do i do?
Old 08-25-2017, 06:19 PM
Roadie's Avatar
Unscrew the plug?
Old 08-25-2017, 08:46 PM
Phil150's Avatar
I just reinstalled a plug earlier this evening. The rear passenger one. Socket and extension got stuck inside on it. I just took another extension with a swivel socket and wiggled around till it attached and lightly turned both ways basically wiggling it and slightly tugging upwards and got it out. Mind you it was a spark plug socket with the rubber lining inside it, so if you used a normal socket it might be even easier.
Old 08-26-2017, 12:05 AM
Unscrew the plug, remove socket when both pieces are in your hand, and try again
Quick Reply: how to take head off 1999 ford f150 because of socket stuck on plug.
