Missfire..... Help....
Old Jun 29, 2017 | 01:59 PM
Ushika69's Avatar
Angry Missfire..... Help....
hi guys... im new member from republic of georgia n i need help..... :/ i have 5.4 triton 3v, 2006.... engine has missfire on cylinder 1, i tasted spark plug works fine also cop and also injector.... can anyone help me? i dont know what to do... only one is left to test compression... its first lincoln in here so no one(mechanics) knows what to do.... thnx...
Old Jun 29, 2017 | 06:17 PM
Ushika69's Avatar
also i checked fuel rail pressure with obd2 scanner and result on KOER is 264 kpa(38psi) and KOEO 336 kpa(48 psi) can someone say is the fuel rail pressure and fuel pressure same? and if yes is this range normal?
Old Jun 30, 2017 | 01:16 AM
That pressure sounds okay, it's controlled by the FPDM mounted on the frame rail above the spare tire. The FPDM has a tendency to corrode.
I would probably *replace* the spark plug, cop, and injector in that order.
Old Jun 30, 2017 | 09:08 AM
Ushika69's Avatar
spark plugs and cops are new.. injectors.. itested they are spraying normall, also engine has misfire on cylinder #1 so i changed their places ex: instaled #1 injector on #5 and #5 on #1 but nothing changes misfire has still cylinder #1.. i think that means injectors are ok.... also somethimes it starts hard.. i dont know maybe its bad intake manifold.... :/
Old Jun 30, 2017 | 12:52 PM
Ushika69's Avatar
News
Today when i was testing fuel pressure i removed air hose from fuel regulator and nothing changes.. pressure was same.... i saw on other forums that when ure removing this hose pressure must rise... :/ does it means that pressure regulator dosnt works?
Old Jun 30, 2017 | 12:56 PM
Roadie's Avatar
Check the compression in the #1 cylinder to rule out a mechanical problem.
Have you tried switching the cops around?
Old Jun 30, 2017 | 01:08 PM
Ushika69's Avatar
Yes im going to check compression but no one have tool here for american car... im searching... not only cops i switched several times cops, spark plugs and injector but every time misfire #1, but today i found that removing vacuum hose from pressure regulator changes nothing, it makes me think about regulator maybe it fails... :/
Old Jun 30, 2017 | 01:30 PM
The fuel pressure regulator on the fuel rail with a vacuum hose was not used after 2003, what you should have is a FPDM on the frame rail above the spare tire. This controls the fuel pump electronically.
You may be thinking of the fuel pressure sensor.
The unique head design on the 5.4 3 valve engine requires a special adapter to test compression.
You may want to remove the passenger side valve cover and check the lash adjusters and cam followers for the #1 cylinder.
Old Jun 30, 2017 | 02:14 PM
Ushika69's Avatar
mmm yes also i removed connector and hose from pressure sensor and nothing changes.. and what is this on my attached picture?
Old Jun 30, 2017 | 02:20 PM
Picture is not quite big enough to see what you are talking about. Instead of using an attachment, click the image icon and upload the full size picture. I'm thinking it's part of the evaporative emission system.
Old Jun 30, 2017 | 02:52 PM
Ushika69's Avatar
aha youre raight its Vapor Canister Purge Valve and if you know, removing hose and connector from pressure sensor must change rpm or fuel pressure and etc?
Old Jun 30, 2017 | 03:31 PM
Ushika69's Avatar
how to read this codes?
Old Jun 30, 2017 | 04:45 PM
You need a OBD2 scanner that doesn't require any addons.
I think the only thing the pressure sensor does is report the fuel pressure to the OBD2. I don't think it affects the pressure unless the PCM is confused by the incorrect raw data.
Old Jun 30, 2017 | 06:21 PM
Ushika69's Avatar
i have obd2 but obd isnt writing any codes about this, only p0301.....Cylinder 1 misfire detected.. ouuu im so tired im searchin problem more than 6 month and cant find
Old Jun 30, 2017 | 07:14 PM
You need to get the exact P21xx, P01xx, and B16xx codes with a scanner.
If the spark plug, cop, and injector are good in #1, then it's a compression or some related mechanical issue as described. It *MIGHT* be a wiring issue, such as a connector on the cop or injector.
