Old Jan 27, 2016 | 01:11 PM
Peterverb's Avatar
I am looking at buying my first F150, to tow a 2500lb TT. I looked at a 2007 4x2 Supercab 4.6l V8 truck yesterday with 80,000 miles. It does not come with the factory tow package, only a hitch. The sales guy at Ford Dealership checked and told me that the truck is good to tow up to 4000 pounds as-is, without any other modifications. That's down from the 6500 rating with tow package. Can anyone tell me if this is correct info? And if this would be a good truck to haul my trailer over mountains etc in the summer? Thanks in advance for any advice you can give.
Old Jan 27, 2016 | 01:57 PM
JackandJanet's Avatar
Personally, I'd pass. That 2500# TT is probably going to weigh more like 3000-3500# by the time you have it ready for travel. And, it may well weigh more than 2500# to begin with.
The trailer you are considering would need an electric brake controller too.
I strongly recommend you buy a truck with the factory tow package if you're going to tow anything more than a simple utility trailer.
Don't get me wrong, the truck you're looking at would certainly pull the trailer without difficulty, but things would not be set up properly for safe towing.
- Jack
Old Jan 27, 2016 | 03:35 PM
I think you would be fine as long as it's a Class 3 hitch and you add a transmission cooler. I can tow 3000# with my 4.2 V6 without factory tow with no problem. The 4.6, with or without tow package, will tow 5000# safely.
Yes, you will need an electric brake controller and a 7 pin rear harness unless the TT has surge brakes. If the TT doesn't have brakes, you can't legally tow it in most states anyway.
Old Jan 27, 2016 | 04:15 PM
I may be wrong, but looking at the OP's post, I think the truck has a bumper hitch. I would not use that kind of hitch to tow the size trailer he's got.
This was my reasoning in recommending a different truck.
- Jack
Old Jan 27, 2016 | 05:29 PM
If it has an aftermarket Class 3 hitch with a real 2" receiver, no problem. If it's just a ball bolted to the bumper, that's a no-go but a real hitch can easily be installed. Bumper ***** are fine for small utility trailers staying local, that's about it.
Old Jan 28, 2016 | 01:34 PM
DYNOTECH's Avatar
I have a 97 4x4 trailer tow, off road pkg with 3:55 posi rear gear. Personally I would look for a truck with a 5.4 and 3:73 gear if you are talking mountains... I put a 2007 4.6 PI engine that I hand built in my truck and in the hills of northern Michigan I sometimes wish I had more power while pulling a 26 ft pontoon boat. It will pull but not without downshifting. Not sure what gear that truck may have but a 3:73 would be a plus and a 5.4 would be a big plus... JMO
Old Jan 28, 2016 | 04:42 PM
10th Gen bumper is rated for 500/5000. It's no slouch.
Old Jan 28, 2016 | 09:57 PM
True, but it's at the wrong height and gets the tongue too close to the back of the truck to make it a confident tow. If you jackknife the trailer, you could very easily damage the truck.
Old Jan 29, 2016 | 10:45 AM
The bumper hitch also puts all the tongue weight on the rear axle of the truck. This lifts the front, reducing braking and steering effectiveness.
Yes, you can certainly add a Class 3 hitch, a transmission cooler, wire it for a 7-pin connector and add the trailer brake controller. But, I suspect there is a used truck out there with the factory tow package already installed for not much more than is being asked for this one that needs the additional parts.
Adding parts to a truck is expensive. But, a truck with parts already added does not significantly change the resale value.
Again, I'd only use a bumper hitch to pull a small utility trailer, even though the bumper is rated for 500/5000#.
- Jack
Old Feb 11, 2016 | 10:50 PM
WSonner's Avatar
The bumper Ball is definitely not good..I found a used Class 3 hitch for not much money, had an electric brake controller installed for $80 bucks on my old 97 4.6 L 2 wheel drive F150 Supercab with 3:55's and pulled my 25 ft trailer just fine here in Oregon, about 5500 lbs. I'm guessing ...going up the mountain passes I shifted down & could maintain 45mph over the Siskiyou Summit & similar passes, floorboarded! Not ideal by any means but it did fine & was very stable for a year then I got my 02 F150 with the 5.4 & tow package...So much better!
