First time Ford owner
Old May 27, 2015 | 03:55 AM
tomfordf15001's Avatar
OK I have replaced coils and plugs on 2001 f 150 5.4 and I still have a shutterr problem all the way from 1st gear on up but if I back off of the gas it rides smooth there's this fine line in which it will throw the truck forward and backwardas if somebody is tugging on it from behind please help !
Old May 27, 2015 | 11:54 AM
Good to have you here. I'm moving this to the V8 forum as you will likely get more help there.
Old May 27, 2015 | 01:32 PM
What brand coils and plugs? Did you use dielectric grease in the boots? Coils fully seated on the plugs, connectors properly connected?
Old May 28, 2015 | 10:02 AM
jethat's Avatar
A scan tool that read live misfire counts is so good. Other then that its process of elimination. Motor craft plugs are the baseline. Cheap coils can fail out of the box.. Again Motor craft parts..
Old May 31, 2015 | 05:18 PM
DYNOTECH's Avatar
Clean your MAF and check all your injector connections as well.
