Ford 5.4 cam phaser and timing set post swap. NEED ADVICE
Yep the new timing set came with Tensioners and Seals/Gaskets along with all of the other timing parts.
http://www.rockauto.com/catalog/more...844&cc=1433355
The gaskets is a green o-ring type seal pre-installed on the back of the tensioners when the timing set came. You could take them off but they came in the back of the tensioners already.
