2000 f150 cylinder head question
Old 01-20-2014, 07:50 PM
wlightaul's Avatar
Question 2000 f150 cylinder head question
i have been looking on ebay for a cylinder head for my 2000 7700 series with the 5.4. when i look through the compatibility part i see "Right for a 2000 FORD F150 8-330 (5.4L), gasoline (unleaded), except Lightning, except 7700 gross vehicle weight; right" I realize the 7700 is basically a f250 but isn't a 5.4 a 5.4?
Old 01-20-2014, 08:46 PM
jethat's Avatar
there is a critical differense in that the heads should be PI or performance inhanced Prior 99 all F-150'd had non PI heads after 99 they are PI. You should have pi heads so you want PI heeads to replace them. And it is a major deal. Cant use a pi intake with non pi heads. Why not just get the ones on it rebuilt. I bet I could get a set of heads redone for $250
Old 01-21-2014, 06:27 AM
wlightaul's Avatar
Ok thanks I did not know that. The one i am replacing a friend screwed up trying to drill out a broken manifold stud. if it wasn't for that it would be fine.
Old 01-21-2014, 10:34 AM
jethat's Avatar
It is likely a machine shop could repair that damage. Thats what I'd do first. Take the damaged head off and see if there isnt some machine shop voodo they can do to fix it.
Old 01-21-2014, 01:50 PM
Tasca Ford Parts's Avatar
Former Sponsor
I agree with Jethat, a machine shop can probably fix it right up.
As for a 5.4 being a 5.4, as far as I can tell the 7700 thing doesn't come in to it at all. Ford has superceded that head 2 or 3 times up to a 2009 part number and before anyone says that Ford didn't use a 5.4 2v in a 2009 F-series you are correct but they did still use a 2v in the Econolines
What's your budget for a cylinder head?
-Steve
Old 01-21-2014, 06:01 PM
wlightaul's Avatar
At the moment I only have about $100, that's why i was looking for a used one. I could go to the pick n pull near me to get one for $56 when it warms up. I'm fixing it up here and there a little at a time, due to a friend hitting a pole on me.
Old 01-21-2014, 08:39 PM
jbrew's Avatar
-Steve
Right, - not sure why that's even in there, - but it's not the first time something like that was in a the description lol.
I can't recall what model years the Van's and F250/350's had the updated heads that ALL F150's had from 99+. 2000 or perhaps 01 for the 3/4 tons, Vans, I can't be sure. You might be able to find that info..
OP - Yea, just make sure it's a PI head. That's what you need for that engine. PI's are stamped on the castings and have square ports. Non PI heads have round ports. That's the giveaway upon visual inspection.
Old 01-23-2014, 05:48 PM
wlightaul's Avatar
thanks guys. jethat with the damage the only thing they would probably be able to do is make a bigger hole and thread it for a bolt, which I may do for now.
Old 01-23-2014, 05:53 PM
jethat's Avatar
Take it to a machine shop and ask.if thats all you need done it might be cheaper then you think. there are also inserts they can install.
Old 01-24-2014, 10:35 AM
Former Sponsor
There's lots of ways to fix it beyond hogging it out for a bigger bolt, check out this link http://www.timesert.com/html/mtrcsert.html
And that's just one of many brands and styles of inserts.
-Steve
Old 01-25-2014, 03:05 PM
msgtcarew's Avatar
-Steve
Very good suggestion! No one has mentioned early 2 valve heads & 03 & up 3 valve heads. 97-02 had 2v. JMO
Old 01-25-2014, 04:38 PM
glc is offline
Not exactly - with the 5.4 2V, 97 and 98 are non-PI and 99 to end of production are PI. The first 3V heads were in the 04 NBS F-150, other vehicles switched over at different times. The E-vans never switched.
Old 01-31-2014, 08:39 AM
wlightaul's Avatar
-Steve
ill have to look in to this but truck got put on hold due to haaving to redo the burst pipes in the house.
Old 01-31-2014, 02:24 PM
Former Sponsor
Ouch, no good. I hope you get it taken care of with a minimum of property damage.
Water damage sucks.
Old 01-31-2014, 03:15 PM
jethat's Avatar
I'm a flood clean up carpet cleaner. Frozen pipes are my bread and butter this time of year..
Quick Reply: 2000 f150 cylinder head question
