help
Old Nov 22, 2012 | 07:37 AM
hicknick514's Avatar
help
hey guys so first things first...2004 F150 5.4 150K EDGE PROGRAMER, ROUSH INTAKE,FLOWMASTER EXHAUT..i have a good general understanding of how engines operate so your not talking to a inexperienced mechanic but i am also NOT a know it all......so my 2004 f150 5.4 with 150k has had a jerking issue....read up on it and i heard its most likely a coil goin bad so i continued to drive it until it threw a code so i knew which one to change(not rich cant change all)well i threw a code ok......
p0012[intake camshaft position timming over retarded bank1
p0172 system to rich bank 1
p0174 system to lean bank2
po303 cylinder 3 misfire detected
p0316 misfire detected on startup (first 1000 revolutions)
p0340 camshaft position sensor A circuit intermittent (bank 1 or single sensor)
now it runs real rough at idle....FML
so far changed coil number 3(third one back on left side)
no change
so then i unplugged coil number 1 while the engine is running and still no change in idle......then i plugged it back in and did the same to coils 2,3,4 still no change
unplugged coil 5 and idle got worse.....plugged it back in and did it again to coil 6 and idle got worse again and thats where im at
so next step is camshaft position sensor?
PLEASE let me know what you guys think......i am hoping this already happened 2 someone and i just couldnt find the thread
Old Nov 22, 2012 | 08:05 AM
sam1947's Avatar
I assume the plugs have been changed ? Do the low dollar things first.....new fuel filter, clean the MAF. clean the TB. Clear all codes and re-test. Probably looking at weak coils (COPs) or at the very least the boots and dielectric grease. Sometimes a single item can trigger multiple codes.
Old Nov 22, 2012 | 09:48 AM
jbrew's Avatar
no change
That might be because, -the third back on the left side would be coil/cylinder # 7. Which is also on bank 2.
Old Nov 22, 2012 | 11:31 AM
Throwing a rich code on one bank and lean code on the other bank is indicative of something like a blown fuse or a wiring issue.
Jbrew is saying "left" = driver's side.
Old Nov 22, 2012 | 12:04 PM
jbrew's Avatar
Right and left of the vehicle is determined from operator vehicle correlation in motion. That would be under common sense? Well, that's where I'd put it.
Old Nov 22, 2012 | 02:27 PM
Well, it's possible the OP is calling left and right from the aspect of standing in front of the truck. Just trying to clarify.
Old Nov 22, 2012 | 03:16 PM
jbrew's Avatar
Which is exactly what I was trying to clarify. What, you don't approve of my methods ? Geezzz....
Old Nov 23, 2012 | 05:12 AM
code58's Avatar
Brew, I didn't kmow you knew Swahili.....
Old Nov 23, 2012 | 07:45 PM
jbrew's Avatar
I know some of it; - speak very little tho. I guess every now and again I have to purge the absorbed. So you may see a little spewage, here and there. Sorry.
Old Nov 23, 2012 | 08:56 PM
i replaced the 3rd one back left side as if you are standing in front of the motor
Old Nov 23, 2012 | 09:05 PM
i did change the plugs at 120k
Old Nov 23, 2012 | 09:07 PM
and the fuel filter at 147k
Old Nov 23, 2012 | 11:29 PM
Takeda's Avatar
What kind of plugs did you use? From the codes, you could also have timing chain/tensioner issues due to the camshaft position error codes. Bad cam phasers will also cause the camshaft position error codes.
Old Nov 23, 2012 | 11:45 PM
IR0NS1N's Avatar
Change the camshaft position sensor. Your pull valve covers and see if timing is off. Possible cam jumped some teeth like guide or tensioner is junk
Old Nov 24, 2012 | 06:59 AM
jbrew's Avatar
That helps!
Posts 13 and 14
