ltft
Old Oct 13, 2012 | 05:57 PM
ncb's Avatar
ncb
ltft
obd test shows ltft b1 b2 @0.8
stft b1 b2 @99.2
is this normal? my truck idles fine but spits and sputters as rmp increases or is put under load. would a clogged converter would cause this??
Old Oct 14, 2012 | 12:15 PM
Need more info. What engine and year, mileage? Has normal maintenance been done? How many miles on plugs and fuel filter? has throttle body been cleaned?
Old Oct 14, 2012 | 01:46 PM
ncb's Avatar
ncb
sorry i have an 03 xl supercab with a 4.6 I had a tbs code and changed the whole throttle body out cleaned the maf and installed a new fuel filter there is alot of miles on the truck but am not sure about the wires. the fuel pressure is within specs I just bought the truck and this is the way it came. I thought it might be something simple to repair ie vacume leak or clogged filter but as usual not that simple LOL
I am also getting a po755 code This is shift solenoid B which should not affect the engine
as stated the truck starts and idles fine and smooth but turns to #@%$ when i put it in gear and under load
If the converter was plugged would it still start and idle as smooth as it does???
Old Oct 15, 2012 | 10:48 PM
ONELOWF's Avatar
How are you getting the stft's and ltft's? They are not static numbers, they change constantly, maybe you are describing a range or average.
How are you checking fuel pressure? Scanner? FP should be checked at the fuel rail with a gauge, vac line from fp regulator removed and plugged to test, looking for ~39 psi at idle.
Motorcraft fuel filter, of course.
Yes, a clogged cat can behave in the way you describe, but that is an extreme situation you describe. Crawl underneath and tap them gently with a hammer, listen for rattling.
Maybe change your atf and filter for starters.
http://engine-codes.com/p0755_ford.html
Old Oct 16, 2012 | 07:50 AM
Muffler shops have the equipment to test for clogged cats.
