Going to buy E-fans Are they really worth 600$
Old Jul 26, 2012 | 05:06 PM
patrick141's Avatar
Question Going to buy E-fans Are they really worth 600$
I'm going to buy E-fans for my truck soon, but before I do I want to know if they are really worth 549.99$. would it really give my 17 more horse power and 3mpg. and will I notice a major difference in power.
I'm looking at the flex a lite e fans http://www.flex-a-lite.com/auto/html...-electric.html Or would you suggest another brand.
Please help me out with this.
Old Jul 26, 2012 | 05:24 PM
Takeda's Avatar
Check out this thread. You will see a link I posted where a guy converted his OEM e-fan setup to a mechanical fan/clutch, and lost .5MPG. The only advantage I see you will get if you buy the e-fans is a lighter wallet:
https://www.f150online.com/forums/ot...lay-fault.html
Old Jul 26, 2012 | 05:36 PM
patrick141's Avatar
Yes I see the problems... but that's troyer not flex a lite or do you think I'll have the same problems.
Old Jul 26, 2012 | 06:34 PM
Takeda's Avatar
With the number of components with an e-fan system, it will be less reliable than the OEM mechanical fan/clutch.
Old Jul 26, 2012 | 06:47 PM
429 boss mustang's Avatar
E fans are reliable. Troyer fans are good. People just have issues with the controller.
Old Jul 26, 2012 | 07:03 PM
str8t six's Avatar
i wouldnt say they are worth $600. but i picked up some fans off a ford windstar for $60
and bought a controller for $140. you can even do it alot cheaper than that too!
Old Jul 26, 2012 | 07:21 PM
Takeda's Avatar
Is the 2nd picture what your final setup looks like? What keeps your wiring out of the serpentine belt, or chaffing on the radiator?
Old Jul 26, 2012 | 07:28 PM
str8t six's Avatar
that was right after i got done with it.
the wire isnt close to the SC belt, and there is tubing around the wires now.
Old Jul 26, 2012 | 07:36 PM
patrick141's Avatar
That sounds like a good idea. And I saw your lighting supercharger swap. How did you do the swap, what all did you replace and how much was it. See that's part of wy I'm doing the e fan I'm getting ready for one.
Old Jul 26, 2012 | 08:01 PM
str8t six's Avatar
idk the final cost, but i would say close to 3k or more
https://www.f150online.com/forums/19...ap-thread.html
Old Jul 26, 2012 | 08:05 PM
etruck's Avatar
hi new to forum I'm trying to figure out how to post a question could you help
Old Jul 26, 2012 | 08:13 PM
patrick141's Avatar
First you go to forum's home, then go to the category you want then at the top left corner there is a button that says new thread... there you go
Old Jul 26, 2012 | 11:07 PM
thebigbc's Avatar
The thread that Takeda showed you was my thread. I will say this, when the controller failed, I was MAD!
But Troyer did replace it no problems what so ever. The controllers work great now, and now that the whole system works as it should I will say that my motor temp doesn't get higher than 195-197 any more. That is what I bought it for, not for the HP, or the MPG's. Just for the better cooling. And it does just that.
As long as the controllers hold up, I foresee my self being happy and content with the setup for a long time.
E fans are a good thing. If I could go back in time, I would have just bought the fans alone from troyer and bought a different brand controller. But the world doesnt work that way.
Old Jul 26, 2012 | 11:48 PM
patrick141's Avatar
I am really thinking about doing this like in the next couple weeks. So you seem to be the most knowledgeable on this so, if I want to do it right should I use troyer or Flex a lite and should I use there controller or a different brand if so what brand.
Tell me my best option... I want to do this right.
Old Jul 26, 2012 | 11:57 PM
str8t six's Avatar
honestly, there are numerous ways to go about doing efans. there are DCC, Derale, troyer, etc.. tons of choices for controllers.
i chose to use mikes controllers. lots of Lightning and harley guys run his controllers without issue, and he has awesome support if anything should happen.
http://madenterprise.com/All_F150.asp
i chose OEM fans for reliability
