4.6 coil packs interchangeable?
Old May 19, 2012 | 06:28 PM
mlangdn's Avatar
I have a bad coil pack on the driver's side - its spits fire in the dark just above the wiring harness. I have one on my bench that came from the passenger side of a wreck. It looks the same, so I was wondering if I could use it on the drivers side.
Old May 19, 2012 | 06:39 PM
sam1947's Avatar
Short of someone giving you another answer, you could go to RockAuto.com and compare the part numbers..that could help. Just my .02
Old May 19, 2012 | 06:46 PM
mlangdn's Avatar
Thanks - I went to rockauto and found the part. Has to be interchangeable because each part number says two needed for vehicle. That's what I needed to know!
Old May 19, 2012 | 06:47 PM
DYNOTECH's Avatar
They are the same which makes them interchangable.
Old May 19, 2012 | 06:54 PM
mlangdn's Avatar
Thanks Gentlemen!
