further damage to f150?
Old Apr 7, 2012 | 04:59 PM
ajc91907's Avatar
I have 2002 4.6 2wd, just drove four hours out of state and noticed truck lurching while going uphill. First time i have had any problem with this. Believe it's probably a coil on plug problem. Is there risk in further damaging my truck by driving it home tommorow and then having it fixed, or should i not drive it home. Really need to get it home, but if i will screw up something else, i'll have to make other arrangements. Thanks for any advice you can give.
Ian
Old Apr 7, 2012 | 05:45 PM
DYNOTECH's Avatar
Hard to say it depends what the real problem is. I would try and find out what is going on first as 4 hours is quite a trip home. I doubt much will be open on Easter Sunday. If it's only while driving up a hill a miss shouldn't do damage but...? Could be a fuel filter or sparkplug as well. Stop tonight at a Auto Zone or equivalent and see if you have any codes. A code will tell you which cyl then just replace the coil if its bad and check the sparkplug. Good luck.
Old Apr 7, 2012 | 06:43 PM
jethat's Avatar
If you have a solid misfire it will have the code stored for that cylinder. if it a low grade misfire it may not tell you what cylinder. If its a solid miss I would get the code read like Dynotech said and if its me and I have minimal or no tools I would just unplug the injector for that cylinder and drive it home and fix it there. If its a low grade miss an intermittent deal just drive it home.
Old Apr 7, 2012 | 10:16 PM
If it's misfiring, hit the gas harder to get it to downshift or manually downshift it.
