Strange problem.
Old Apr 3, 2012 | 03:37 PM
F1X540's Avatar
Strange problem.
2004 F150 FX4 5.4
I'll try to make this short.
Vibration in steering wheel in overdrive under load.
I let off throttle, it stops instantly.
Replaced coils twice. Just got it back from local dealer.
They did a smoke test for vacuum leak. Nothing.
Checked for codes. Nothing. When this happens there is no
shudder, missing ,etc. just steering wheel vibration.
The more load the worse. Any other time it is fine.
All steering components tight. Bad steering pump?
After 2 different Ford dealers, and said mechanic
are stumped. Oh yeah, this happened literally
after major engine work by Ford dealer...Also,
I just bought 8 new Motorcraft coils just in case.
But they are not installed..
Any ideas?
Vance
Old Apr 3, 2012 | 03:41 PM
How many miles on the plugs?
Old Apr 3, 2012 | 03:53 PM
SETCHAN's Avatar
Build Tracking Moderator
First thing I'd check is to make sure the weights on driveshaft are still there
Old Apr 3, 2012 | 04:50 PM
DYNOTECH's Avatar
What was the extent of the "major engine work" by the dealer? Was it cab off to remove the engine?
Also check the engine oil level if there is to much oil in the pan (overfill) you will get vibration in the steering wheel under certain conditions.
Old Apr 4, 2012 | 10:39 AM
F1X540's Avatar
Replaced when dealer did engine work. 6 Months ago..
Old Apr 4, 2012 | 10:43 AM
F1X540's Avatar
Engine was no pulled.
Replaced cam, some lifters, chain, etc..
Oil level is fine..I always change it myself.
Old Apr 4, 2012 | 10:50 AM
F1X540's Avatar
I'll check it out..
Old Apr 4, 2012 | 11:27 AM
F1X540's Avatar
Weights all intact..
Vance
Old Apr 4, 2012 | 12:07 PM
F1X540's Avatar
One thing I forgot to mention is, the idle is alittle rough.
Nothing major, but it is not consistent. Some times worse..
Also the steering vibration happens no matter outside temp.
Thanks Vance
Old Apr 4, 2012 | 01:17 PM
kingfish51's Avatar
Check the u-joints. Under load they could cause vibration which would go away when not under load.
Old Apr 4, 2012 | 01:41 PM
F1X540's Avatar
When I was at one of the Ford dealers, they found rear U joint lose.
They replaced it...Still same problem...I went under truck and yanked on the drive shaft. Front to back, side to side, and no play..
Old Apr 4, 2012 | 01:50 PM
F1X540's Avatar
Also the mechanic, ( not Ford dealer) Spent an hour going back and
forth with me as to possible problems. He suggested several things, but was not sure of those either. He told me he was not "going to throw parts at it" until he can figure it out.
BTW, He specializes in trucks. I've had other work done by him and
he fixed all problems. 100%...That's why I always go back to him.
I would NEVER Go to Ford dealer because I found out the hard way, they are idiots!
Old Apr 4, 2012 | 02:02 PM
F1X540's Avatar
BTW,
He has been working on trucks for 25 years, and never came across this problem..He has all local businesses, from big trucks, to trucks like mine go
to him exclusively. He is always busy...So he is not a fly by night business.
Old Apr 4, 2012 | 04:57 PM
chrmar's Avatar
Is your truck 2- or 4-wheel drive? Could be an issue with CV joints in the front axles if 4-wheel drive...
Old Apr 4, 2012 | 06:53 PM
JCR 56's Avatar
If it happened just after the engine work, i would suspicion the engine work.
