Patdon -Factory engine break in???
Old Aug 31, 1999 | 09:28 PM
fordme's Avatar
Question Patdon -Factory engine break in???
Patdon,
Does the factory break in a new motor? For example when you install a new cam you are supposed to run @ 2000rpm's for 20 minutes then drain the oil and refill. If not you know when someone test drives a vehicle they always stomp on it. The motor needs to be broke in before you run it hard.
Old Sep 1, 1999 | 09:41 AM
gearjammer's Avatar
Post
To my knowledge, they don't. I don't think they have time with the demand for this awesome truck. I have been told by my uncle and grandpa (drag racers and backyard mechanics from back in the day)and a few others that you can run it from day one like you would run it 2-3 years from now. I did that with my old Ranger (2.3 I-4) when I bought it, and it never saw the shop floor. Considering the 131,000 miles on it when I traded it, that's not too shabby. I've done the same with my new truck (1998 4.6L V-8) and it's running like a champ.
For what it's worth...
1998 F-150 XLT 4x4, Regular Cab, Short-Bed, 4.6L V-8, 5-Speed, 3.55 Rear Gears, Dark Toreador Red
Old Sep 1, 1999 | 10:14 AM
TELLENBERGER's Avatar
Post
The Triton engines are not run at the factory. They are checked for clearance and construction but no break in period.
97 F-150,4.6, Reg Cab, Flareside, Air Aid Kit, TransGo Shift Kit,
Superchips, Gibson Single Cat Back, ******* Bed Cover,
EGR Bug Shield, XL Full Length Running Boards,
Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
Old Sep 1, 1999 | 01:32 PM
patdon.'s Avatar
Post
fordme
As Tellenberger said the Triton engines built in Windsor are not Hot Tested. But at the Essex Engine Plant also in Windsor, where the 4.2 is built, every engine is Hot Tested for about 4 minutes. This is not really a break in process, it is really to ensure that the engine runs properly.
Black 99,flareside,SC 4.6, 3.08 chrome Westin step bars, Extang tonneau, Magnum Deflector, SUPERCHIPPED,KN air filter
