Changing coils, need advice
Old Jan 8, 2012 | 08:42 AM
starkyb's Avatar
I will be changing my ignition coils soon on my 2001 S crew 5.4 and I wanted to know if I needed to remove anything to get them out.
Old Jan 8, 2012 | 09:34 AM
Galaxy's Avatar
Nope. Sometimes moving the fuel rail on the left side helps a little bit, but it doesn't have to be removed. Just remove the hold down bolts on the rail and it'll give you some wiggle room.
Old Jan 8, 2012 | 09:52 AM
starkyb's Avatar
Thanks Galaxy. I was talking to mechanic friend yesterday and he was saying that a leak in one of the vacuum hoses could cause misfiring. Would that cause
a couple of the pistons to misfire. I got a code 304 and 307 (4 and 7 cylinder misfire. The plugs are less than 2 years old.
Old Jan 8, 2012 | 10:39 AM
jethat's Avatar
You would get a lean code if you had a vacuum leak serious enough to cause a miss fire, What plugs did you use? mod motors are ssuper picky about plugs.. Motorcraft are the safe bet..
Old Jan 8, 2012 | 11:45 AM
starkyb's Avatar
I'm not sure what plugs but they were installed by a certified mechanic in my city. The vacuum lines looked to be ok. I will start with the coils and go from there. Thanks
Old Jan 8, 2012 | 04:25 PM
SupercrewLightn's Avatar
Look up Mike Dunn @ Madenterprise. Order a set of cop screws- next time the you need to change your plugs-coils,etc you will thank yourself.. Here's the link- http://www.madenterprise.com/All_F150.asp
