Rattleing sound when starting engine
Old Jan 6, 2012 | 08:22 PM
F150Bostonian's Avatar
When I start my truck I sometimes hear a sound that almost sounds like a little rattle upon starting, sometimes the sound is not there. Is this normal?
Sorry for all the questions but I just got this truck and need to know what is normal or not. My last car has me paranoid about sounds from the vehicle lol
Old Jan 6, 2012 | 08:42 PM
dozerdog's Avatar
may be your exhaust pipes are a little loose somewhere
Old Jan 6, 2012 | 08:45 PM
5.4 3v? Timing chain tensioner can bleed off oil pressure occasionally and a lot more if the wrong oil filter is used, causing what you're hearing, start up rattle. Only use the recommended oil and oil filter with an anti drainback valve. I use Motorcraft exclusively.
Old Jan 6, 2012 | 08:57 PM
Yes 5.4. The oil was changed at the ford dealership so I would assume they are using the motor craft filter. When asked they said that is what they use.
Old Jan 6, 2012 | 08:59 PM
Mine does it occasionally. Once the oil pressure builds the noise stops. Honestly I don't worry about it.
Old Jan 6, 2012 | 09:02 PM
Yea, the noise does stop right away. Once in a while the engine sounds rough when idling upon first starting then goes away within a minute once it warms up. Do you get this also?
Old Jan 6, 2012 | 09:11 PM
I've never experienced that. The rattle hasn't happened in a long time either.
Old Jan 6, 2012 | 11:34 PM
marklt6002's Avatar
x2 on the timing chain tensioner,mine would rattle upon start up almost every morning until the chain broke a guide.every time it rattles the tensioner is putting little pressure on the chain(until oil pressure builds up)so the chain jumps all over and ends up breaking a guide.if it does it often i would keep an eye on it before it gets expensive.
Old Jan 10, 2012 | 12:01 PM
So as I'm typing this I was just informed that I need a new engine. I am heated right now, I bought this f*cking truck a little over a month ago from a Ford Dealership.
They said the noise was coming from a cam shaft or something like that. WTF...
Old Jan 10, 2012 | 12:30 PM
jethat's Avatar
I'd get a 2nd opinion. If it the tensioners that can be repaired. How many miles are on it?
Old Jan 10, 2012 | 01:13 PM
50k miles on it. The good news is that Ford is covering the cost of the engine, it's still under their factory warranty.
