Wont start....Need some help.
Im in a pretty bad situation here! heh Truck just plain out wont start......Heres the rundown up to this point as far as I know: The last person who drove the truck was my mom, brought it to my house parked in driveway, shut it off done. I go to start it a few days later, it cranks over very slow, brand new battery. Pop the hood and notice somehow the green vac line came off the egr (kinda werid). So i take the alternator in for testing and it is bad, I buy a brand new one and put it in, charge the battery back up, cleaned the terminals, cables real good and everything is nice and shiny clean. Go to start it and it cranks over just fine and "stumbles" every now and then, like a few cylinders hit but still nothing. Ill say I havent done any tests on anything yet just so you guys know. Checked the fuses, none blown. Vac lines are all connected. 1 thing i did do is release the pressure on the passenger fuel rail a couple times after i cranked it, and there was some pressure on it and gas came out but im not sure if that can tell me im getting fuel or not. Any other suggestions on what could be the problem or things to check that I missed? Thanks.
2001 4x2 5.4
2001 4x2 5.4
Monitor the voltage. Since your alt was dead, it could have put a strain on the battery... even a new one with a fresh charge. Check the voltage at the terminals and also check it under load while trying to start it. Or a simple way is to turn your headlights on while trying to turn it over and look to see how bad they dim. Listen for the pump, should prime with the key on, engine off position. You can also check the inertia switch, passenger kick panel. Fuel pressure test..
