sparkplug snapped
Old Nov 16, 2011 | 02:54 PM
loghog's Avatar
sparkplug snapped
new spark plug snapped, now spins freely stuck in hole.
Old Nov 16, 2011 | 02:57 PM
loghog's Avatar
new spark plug snapped in hole now spins in hole. can you help me?
Old Nov 16, 2011 | 03:08 PM
kevhead75's Avatar
is this a 04+ plus 5.4 3v motor?
Old Nov 16, 2011 | 03:13 PM
Could you have cross threaded it and stripped the threads?
Old Nov 16, 2011 | 03:14 PM
loghog's Avatar
no its a 1997 4.6L Triton
Old Nov 16, 2011 | 03:16 PM
Another possibility is that it had previously blown a plug, had a helicoil put in and now the helicoil has broken lose and is spinning.
Old Nov 16, 2011 | 03:17 PM
loghog's Avatar
The plug was not cross-threaded, It was just being tightened to 85ft/lb. The specs said to tighten them to 100 ft/lbs. The plug snapped at 85.
Old Nov 16, 2011 | 03:19 PM
loghog's Avatar
Helicoil is possible. It's #2 Plug so it's hard to see. If it is, do I have to pull the head?
Old Nov 16, 2011 | 03:23 PM
If you were tightening a spark plug to 100 ft/lbs, there is your problem. It should be 28 ft/lbs.
Old Nov 16, 2011 | 03:24 PM
I think you are going to need to get the plug out, then get a Timesert kit and install a Timesert.
Old Nov 16, 2011 | 03:39 PM
Where ever got them specs from.....throw it away.....as stated before 28ft/ lbs or 38 nM...
And if this wasn't the only one you installed the others that you did put in at 100ft/lbs might have had their threads stressed also and that also will be needing to be addressed......
Old Nov 16, 2011 | 03:45 PM
azmidget91's Avatar
Wow
Old Nov 16, 2011 | 04:31 PM
JCR 56's Avatar
Double wow . Didn't strip until 85 ft. lbs. I wouldn't have thought they would
have took that much pressure.
Old Nov 16, 2011 | 05:46 PM
Toyz's Avatar
triple wow
Old Nov 16, 2011 | 05:57 PM
sam1947's Avatar
Originally Posted by Toyz
triple wow
One would have thought a little common sense would have come into play here (85 to 100 ft lb on a SPARK PLUG !!). But then, sense isn't common anymore I guess.
