What Oil do you use?
Old Aug 18, 2011 | 09:44 AM
In my f150 it was amsoil signature series 0w-20w with amsoil oil filter.....now in the STA I run the MC oil and filter....
Old Aug 18, 2011 | 09:47 AM
Originally Posted by 88racing
In my f150 it was amsoil xl series 0w-20w with amsoil oil filter.....now in the STA I run the MC oil and filter....
Soooo, the STA doesn't rate the good stuff!
Old Aug 18, 2011 | 09:58 AM
Soon it will......just waiting for the miles to rack up until the next oil change.....the garage princess doesn't get driven hardly at all during the week.....
Old Aug 18, 2011 | 10:12 AM
Just kidding, I actually think the MC does the job just fine.
Old Aug 18, 2011 | 10:16 AM
As do I.....
Old Aug 18, 2011 | 10:23 AM
jbrew's Avatar
That's cuz it does.
Old Aug 18, 2011 | 11:27 AM
Gotts2BMe's Avatar
2v's need the thinner oil for the cam bearings. I have seen more than a few with the cam bearings wiped out. The 3v guys should really start weighting them up to a minimum of 5/30. You need the pressure for those cam phasers. 3 years ago with my buddies 05 5.4 the cam phasers were making a lot of noise at 70,000 miles. Truck is still running on the original cam phasers at 170,000 miles. They are still quiet.
Old Aug 18, 2011 | 11:30 AM
My 05 has 134,500 on it and has never seen anything but 5-20. Barely moves on the stick in 4500 miles and no noise other than a little injector noise.
Old Aug 18, 2011 | 12:02 PM
mmdunne's Avatar
I used Penzoil exclusively in my 1990 Mazda B2200. Bought the truck new, kept driving it even after it was flooded by hurricane Ivan back in 2004, and finally sold it a few months ago with 250,000 miles on it because the transmission synchros finally died due to salt water intrusion.
I think oil change interval is more important than oil brand.
Just my $.02 . . .
Cheers,
Matt
Old Aug 18, 2011 | 12:26 PM
I would never run my truck even close to 7500 miles on the same oil, no matter what the life expectancy is on the oil or how clean it is. I will not usually go much over 3000 miles, but that's just me.
Then don't waste your money on high priced synthetic oil. Use the Motorcraft 5w20 semi-synthetic and Motorcraft filter. Walmart carries both.
I use Mobil 1 EP and a M1 filter, and change it once a year or 10k, whichever occurs first.
Old Aug 18, 2011 | 12:37 PM
phil6608's Avatar
Originally Posted by jbrew
Castrol a good one as well.
That's what I run in my truck, and I change it every 3000 miles or one time a year.
Sometimes I don't put 3000 on in a year.
Old Aug 18, 2011 | 12:59 PM
jerhelo's Avatar
Originally Posted by Jwest45
Hey everybody, just want to get an idea of what types and brands you guys are using for motor oil in your trucks. I recently bought my truck, so I haven't change my oil yet, but with my last truck I was running Royal Purple, and I am probably going to stick with it. I just want see what everyone is using before I decide to change mine.
Mobil 1 Full Synthetic with Motorcraft oil filter since the first oil change. I only put about 1,000 miles a year on it so I only change the oil once a year. When it comes out it is almost as clean as when it went in. Engine is quite as can be knock on wood.
The last time I changed it I bought the extended performance because it was on sale for cheaper than the standard 5W-20 Mobil 1....
Old Aug 18, 2011 | 01:11 PM
jbrew's Avatar
Couldn't pay me to use Mobil 1, since SOME of their oil failed spec testing a few years ago. I won't chance it.
Old Aug 18, 2011 | 01:15 PM
phil6608's Avatar
And I thought I was doing overkill!
Old Aug 18, 2011 | 01:32 PM
FFEMTPSTX's Avatar
moble 1 5W-20 full synthetic with a motorcraft filter unless the there are those moble 1 sales goin on 5 quarts of oil and filter for 30$ isnt bad....and i change it every 5k
