Changed Spark Plugs, DIRT???
Old Aug 14, 2011 | 09:24 PM
jerhelo's Avatar
Originally Posted by jbrew
It matters. You need to fill your info in, -top right corner. That way you won't get the wrong info. We don't know what your driving lol.
I appreciate all of your help, where are you at in Michigan. My entire family is up there throughout the entire state. I left with the military about 15 years ago and miss it very much...
Old Aug 14, 2011 | 09:25 PM
jerhelo's Avatar
At least 28' lbs or they'll just blow out on yuh. Don't use anti-seize. These are 5 thread aluminum heads, - it's imperative that this be done correctly.
I carefully torqued to 28 ft/pounds. Only 5 threads, it seemed like they threaded in quite a bit....
Old Aug 14, 2011 | 09:42 PM
jbrew's Avatar
Yea, your heads are different. They were updated late in 03 for the V8's. Torque is different, but you haven't hurt it IMO. Those heads are 8 or 9 threads.
3Valves - I can't recall when Ford offered the 3 valve V8 for the 4.6L versions. It was right around your model year. I'd have to look that up, but the 3 valves require strange looking plugs compared to original plugs that these vehicles used before 2005.
Old Aug 14, 2011 | 10:14 PM
jerhelo's Avatar
Do you know what the torque is???
Old Aug 14, 2011 | 10:28 PM
jerhelo's Avatar
blownoutsparkplug.com states 28 ft/pounds....I went with that...I think it will be fine....I hope so...
Old Aug 14, 2011 | 11:14 PM
steven'sf1504x4's Avatar
That tq spec is for the 2v 4.6s and 5.4s if you have a 3v tq the plugs to the factory spec i would think cause those dont have blow out issues.
Old Aug 15, 2011 | 01:24 AM
The 3v torque specs are 25 ft/lb. The 3v 4.6 wasn't used in the F-150 till 09.
Old Aug 15, 2011 | 03:07 AM
4.6 3v Wasn't offered until 2009 for the f150's...
The mustang gt's got it back in 2005
Old Aug 15, 2011 | 08:53 AM
jerhelo's Avatar
88racing,
I used the 28 ft/pounds torque, I am assuming that I am fine. I think this is getting a little to much thought. I know when I threaded the plugs back into the heads there seemed to be a lot of thread before it snugged. I can't imagine it blowing the plug out. I have never taken so much precaution with changing out a spark plug and this is the first time I have ever actually torqued them down. I had to go and buy a torque wrench as mine only went down to 50 ft/pounds...
What do you think?
Old Aug 15, 2011 | 09:23 AM
88racing,
What do you think?
How do you know it was 28 when the torque wrench only goes down to 50?????
IMO ......I would get a tq wrench with the right ft/lbs or use an inch/lbs one and convert......
Old Aug 15, 2011 | 09:50 AM
jerhelo's Avatar
No, I bought a new torque wrench as the one I had only went down to 50....I have one now that goes from 20 to 100 ft/pounds....
Old Aug 15, 2011 | 09:55 AM
Good....sorry I didn't catch that.....
Old Aug 15, 2011 | 09:57 AM
jbrew's Avatar
Thanks 88. Yea, I couldn't remember squat, -probably still won't lol. Didn't Ford offer both 2V and 3V 4.6L's for a time, ("trucks") ?
Old Aug 15, 2011 | 10:04 AM
2009+2010......4.6 2v leftovers.....if you'd like to call it that.....must of been some package deal from the factory to the dealer...lol
Old Aug 15, 2011 | 12:04 PM
The 4.6 2v replaced the V-6 as the entry level engine, and it kept the old 4 speed tranny. Ford got it to get better EPA mileage numbers than the V-6. It was actually a very good package for a work truck.
