98' F150 5.4 - Need advice/help
I've got a 98'
F150
5.4
~170K
Appx a 1000 miles ago it ran rough & tripped a sensor for coil pack. I had that replaced along with all 8 plugs and it ran fine for appx 500 miles. Now it's got same symptoms (hick-up when idol & hesitation/ rough under load or through acceleration) only not as dramatic and it has not tripped a code in about 500 miles. Could it be something besides the coil pack? If so, what & how do I fix it?
Any help would be appreciated!
Thanks!
F150
5.4
~170K
Thanks!
Thanks for all the help!
I have not changed the fuel filter since I got it and am not sure if it has been changed previously. I'll give that a try today (probably needs changing anyways) and if it doesn't run better then I'll start looking on Ebay for the coils. Any suggestion to what brand of coils works best??
Thank you for all the help! I changed the fuel filter which looked to be original and also cleaned the MAP sensor. When I took it for a spin, there were the same problems ... Looks like my next step is to get the coils and figure out how to change those & probably all the plugs too while I'm at it. I've gotta get this figured out by the end of the month so I can use that truck to pull a UHAUL when we move 600+ miles. Thanks again!
I will be sure to do that. What about the fuel injectors? Think it's worth $100 to change them out too while I'm at it? The way I understand it, it's just a matter of unplugging the old ones & plugging in new ones when I've already got the fuel rails and boots out of the way??
id say to do what other have said and go ahead and replace all of your coils at once.
it would be like only doing 1 plug at a time when it missed enough to trip the CEL if one goes the rest are on the way mine as well do them all at once. IMO
just my .02 cents
I'm having a hard time finding those brands. Is there another brand that you would recommend?? Thanks!
