Testing a fuel Pump
Testing a fuel Pump
I believe it is time for a new fuel pump on my 2005 5.4. Before I drop the 300+dollars on a new pump I have a quick question. The problem I am having is when the gas pedal is put to the floor it putt putt's and skips and stutters and gives me a low pressure code. If this is being caused by the fuel pump becoming weak would I be able to tell by reeving up the truck with it in park and holding a steady RPM? the plugs were changed 40,000 miles ago and the fuel filter last week. any suggestions would be great.Thanks
Confucius say "filling out profile eliminate guessing" (which often leads to NO help). J pegged it correctly!
