cold startup ticking
Old May 26, 2011 | 08:25 PM
98f150royalblue's Avatar
Question cold startup ticking
on cold start up my 98 4.6l has a ticking , when i press the gas it gets faster,let off it goes away . when warm it stops
Old May 26, 2011 | 08:57 PM
sam1947's Avatar
Have no idea what you have for an engine, but, in reading the forums, if the plugs have been changed recently one might be loose or you could have an exhaust leak at the manifold. some more info would help.
Old May 26, 2011 | 10:25 PM
Toyz's Avatar
What oil and filter are you using.
Old May 29, 2011 | 10:19 PM
Question cold start ticking
fram oil filter 100% synthetic oil some one said somthing about the egr but i dont no im pretty good with chevy and toyota but havnt messed with the ford thanks guys ill check the plugs there is no exhaust leak
Old May 29, 2011 | 10:24 PM
spencerdrewh's Avatar
Ticking huh? Could be a timing chain. Not highly likely but possible. I just worked on a truck the other day that had a ticking noise to it and it was the timing chain.
Old May 29, 2011 | 10:30 PM
Get the Fram off there and see if it doesn't go away. The drain back valve is collapsing. Get a Motorcraft, Purolator or Wix. Just about anything but a Fram.
Old May 29, 2011 | 10:31 PM
it only does it when i first start it than goes away thanks ill get rid of the fram and try that
Old May 29, 2011 | 11:03 PM
jbrew's Avatar
Yea, off the Fram. Hopefully it's not to late. That's the Orange can of death for these engines.
Old May 31, 2011 | 02:50 PM
got rid of the fram no noise thanks guys
Old May 31, 2011 | 02:57 PM
Smile cold start ticking
thanks got it fixed
Old May 31, 2011 | 03:00 PM
Amazing. One more time. And the Fram guy argued that it could not be.
Old May 31, 2011 | 06:25 PM
dozerdog's Avatar
i even put a motorcraft on my wife's neon in place of a fram a couple years ago and the ticking went away!
Old May 31, 2011 | 08:54 PM
Gotts2BMe's Avatar
Mine goes gr... knock, knock, knock, knock, knock when I cold start it...
Old May 31, 2011 | 11:15 PM
DYNOTECH's Avatar
I went to a guys house a couple weeks ago and removed four broken sparkplugs from his 2006 f-150. He calls me a few days later stating that he has a cold start knock first startup in the morning. I asked what type of filter and he said Fram, had him change it to a Motorcraft and the problem went away. A month ago I timed a 4.6 for a guy. He called with the same noise concern told him the same thing and problem went away after he installed a Motorcraft filter. I have to wonder how many of the cold start knock engines we had returned to our plant from dealership pulls that we spent days trying to find the root cause but never could duplicate the problem were from Fram filters. This issue has to be costing customers and even the auto companies a boatload of money.
Old Mar 3, 2022 | 11:24 AM
dione560's Avatar
why would the oil filter matter?
My 2010 4.6L 2v started making cold start noise. Very definitely a lifter. Started after changing plastic intake and washing out the heads. Had also switched oils. Thought it was the cheap oil and perhaps some tars that went from the head down into the motor. Marvels mystery oil stops the noises and so does seafoam. But now im back on the better synthetic oil and 0 additives and the noise is worse. So, time to pen her up and start looking around and consulting people.
