Oil in Spark Plug Socket
Old May 24, 2011 | 10:00 AM
rdstrader's Avatar
Unhappy Oil in Spark Plug Socket
Does this represent a blown head gasket or something worse?
Old May 24, 2011 | 10:12 AM
jbrew's Avatar
It usually represents a sloppy oil change.
Old May 24, 2011 | 02:49 PM
rdstrader's Avatar
The oil is actually in the socket. No oil has been poured, that I am aware of.
Old May 24, 2011 | 03:14 PM
Norm's Avatar
Spilled oil is the most likely cause. It is not head gasket.
Old May 24, 2011 | 09:46 PM
Toyz's Avatar
Let me guess, bank 1... either plug 2 or 3? Yeah, what these guys said. Most likely spilled oil. Only other possible cause would be a valve cover gasket. Or a bad pcv valve seal which I have seen. Allows oil to spew out and run down the valve cover into the plug wells. The head gasket is below the plug, impossible for it to seep oil into the plug well.
Old May 25, 2011 | 09:53 AM
DYNOTECH's Avatar
Also possible that your sparkplug has loosened up and raw gas is being forced into the plug well from the bore. Coolant and gas can appear to be oil when it mixes with the dirt etc. in the plug well.
Old May 25, 2011 | 11:30 AM
NOLAGT's Avatar
I had the #8 plug on my truck be cross threaded from the factory...last 145k miles...but for several thousand of those miles it had backed out enough to let gas exit and make a ticking sound. It actually sounded like the tick was in the bottom end. But when I had the plugs changed the guy said no more ticking...and the #8 plug was real loose and was all funky black in that area.
Old May 31, 2011 | 03:52 PM
rdstrader's Avatar
Thanks for the responses. I will check it out!
