Running Rich?
Old Apr 28, 2011 | 12:36 PM
malexander52's Avatar
Running Rich?
Just had the Flowmaster 50 series SI/DO installed friday. I noticed this morning there is quite a bit of soot in the pipes, more so than I noticed in the stock exhaust pipe. No other changes. Been running a drop in K&N for 25,000 miles, using the same gas, etc...Temperatures have been mild here in Houston. Anything to be concerned about?
Old Apr 28, 2011 | 02:35 PM
kevhead75's Avatar
You are going to get some black soot no matter what. It may hard to diagnose a rich problem soley on that. If you have the ability to look at fuel trims then that would be a sure way of knowing rich/lean conditions.
Old Apr 29, 2011 | 01:49 PM
Clean your MAF - the K&N oil has been known to foul it.
Old Apr 29, 2011 | 02:32 PM
Righto!
Got a can o' MAF cleaner on the bench. Will hit her after work this evening.
Thanks GLC.
Old Apr 29, 2011 | 05:56 PM
jbrew's Avatar
That's because your running a Chambered exhaust now. They sound okay, but your exhaust gases are now going thru a maze. Your factory exhaust is allot better performance wise. The 50 series has to be the worst option as far performance, it's a killer.
