2010 5.4l engine ford f150
Old Apr 16, 2011 | 12:02 PM
Bill737's Avatar
Driving at 80 kilometers and I step on the acclerator I get a horrible sound like a vibration or of air trying to pass thru a pinched hose, dealer can't find the problem . Has anyone else had this problem or knows what is causing the noise. it only happens at full to the mat accleration.
Old Apr 16, 2011 | 03:19 PM
Look inside the fenderwell and see if there's a loose piece of insulation that might be getting sucked into the air intake.
Old Apr 16, 2011 | 09:55 PM
jbrew's Avatar
Where's everything coming from ? As close as you can tell ?? It's not a converter is it ?
Old Apr 17, 2011 | 10:09 AM
Bill737's Avatar
Thaks for the help i will check for anything loose and the sound sounds like it is coming from the center of the dash just under the speaker or in behind the GPS screen
Old Apr 17, 2011 | 10:21 AM
Bill737's Avatar
engine sound
I don't think it is the converter, it sounds like it is coming from inside the dash in behind the GPS screen?
Old Apr 17, 2011 | 01:18 PM
DYNOTECH's Avatar
Are you sure its not detonation. Try running some premium through it and see if it still happens.
