Tune UP PROBLEM
Old Mar 11, 2011 | 12:00 AM
ONELOWF's Avatar
You might buy one of the cheap extendo-mirrors from the parts store, makes it is easy to see in the plug well using a flash light.
Old Mar 13, 2011 | 03:19 PM
1998f150wes's Avatar
well i tried blowing air in in it and it still does the same thing
Old Mar 13, 2011 | 08:49 PM
madferraristi's Avatar
Do you know for sure that there is nothing in there preventing the socket from engaging the hex on the plug
Old Mar 13, 2011 | 09:30 PM
well i can kinda feel the socket slip but it catches and when the plug is coming out it make a squeak noise
Old Mar 14, 2011 | 01:40 PM
ovfdfireman's Avatar
This is a common problem, we had a fleet of 6 - 2005 F150's and and 4 of the six did this when we had the plugs changed, the other 2 we sent to auction. Love Fords but they need to use anti seize!
Old Mar 14, 2011 | 08:26 PM
Completely different issue. The 2005 5.4 used the extended 2 piece plugs. You are comparing apples to oranges.
Old Mar 14, 2011 | 08:51 PM
1997bigredf150's Avatar
I would still say try to look into that hole and see, is has not been uncommon or rocks or other debree to get stuck in there. One way to check woul be to look ath where the socket measures up on the other holes to that one....if they go in deeper then there is something in the hole. If not you might want to just bite the bullet and take it to a local shop.
