cop misfires
Old Mar 11, 2011 | 01:00 PM
bdholsin's Avatar
Thanks 88racing. That's good information. I'm not in a pinch so I can probably order from ebay. If I was in a big yank I'd have to go to my local dealership. I appreciate the suggestion.
Old Mar 11, 2011 | 03:11 PM
bdholsin's Avatar
Just a thought...is there a way to test a coil to evaluate it's function? Something like a resistance test with a multimeter? I know it's #4 (according to my Edge) but if I can test them all I'd like to see if there are any others that are becoming questionable.
Old Mar 11, 2011 | 08:16 PM
nrd10's Avatar
So the way I understand this is cylinder 1 is on the passenger side closest to the radiator. Or front of the engine? Need to replace that one but wasnt sure if it was on driverside or pass side front or rear. Thanks.
Old Mar 11, 2011 | 09:42 PM
Toyz's Avatar
Standing in front of your vehicle looking into the engine bay the cylinder order is like so
4 8
3 7
2 6
1 5
So yes, passenger side closest to the radiator, which would be the front of the engine is number 1
Old Mar 11, 2011 | 09:52 PM
Toyz's Avatar
The manual has a procedure to test primary and secondary resistance. However, that is only a bench test. That does not mean that the coil is not failing under load, causing low grade misfires. So on that level, when theyre bad, theyre bad... otherwise it is almost pointless to test them for issues like yours. If you want to pull them and test them, nothing wrong with that. Something questionable may show up. But when your chasing a low grade misfire that is only present under load or certain conditions, a bench test may not show anything.
Old Mar 12, 2011 | 06:59 PM
jbrew's Avatar
That's correct, -Pointless. Since the misfire monitor will definitely pick up Primary or Secondary failure.
They have to be stress tested with the WDS Rotunda kit or Mode 6'ed for cylinder history. Most of us aren't equipped for that.
The unconventional way is to find the misfire load during a drive cycle. Hold/push, whatever you need to do to increase/force the miss count to satisfy the monitors count enough to produce the MIL/CEL. Which of course directs you to problem cylinder.
However, you could fabricate an LED board tied directly to each coil and wire it thru the firewall and into the cab. LED's connected to monitor coil pulse so that you'll know which one is acting up when it begins to mid fire. Wouldn't be THAT difficult. - A little time consuming maybe and......ate -up lol.
Old Mar 12, 2011 | 07:06 PM
jbrew's Avatar
Originally Posted by snownutt
Along the way I found this... should I be concerned about this oily line? is that a filter in that bulb thingy?
snow
I don't know ? Why would that be oily , there ? I can't think of anything... I guess it could be sucking oil thru the PCV line ? Other than that, I'm drawing a blank, haven't seen that.
Old Mar 13, 2011 | 01:00 AM
Isn't that the IAC muffler?
Old Mar 13, 2011 | 07:08 AM
jbrew's Avatar
Yes.
