Pulstar Plugs Experiment
Old Jan 14, 2011 | 01:26 AM
  #31
Toyz's Avatar
Originally Posted by munoxide
WTF happened to that plug in the middle on the last pic? Did you throw it in the fire or something?
Maybe it was the number four plug, corroded from coolant? That thing had to be misfiring.
Old Jan 14, 2011 | 11:21 PM
  #32
munoxide's Avatar
For sure.
Old Mar 22, 2011 | 11:37 PM
  #33
ak_cowboy's Avatar
That plug was one of the original ones, he was comparing it to the new ones.
Old Oct 26, 2011 | 11:07 AM
  #34
BL4CK3D0UT's Avatar
Haven't been on here in a while...
Probably put about 5,000 miles on these plugs. No issues!
Old Oct 26, 2011 | 12:07 PM
  #35
54regcab's Avatar
Originally Posted by Norm
My stock plugs lasted 140K.
I got 197K on mine.
Old Oct 26, 2011 | 12:10 PM
  #36
54regcab's Avatar
Originally Posted by BL4CK3D0UT
Just installed them! Took me 3 hours at my base's hobby shop but was able to get it. I did not think the plugs were fragile at all and installed in the truck no problem... Didn't even have to gap them! After i started up my truck.... wow! My throttle response was so much better and really enhances the truck's power. As for gas milleage, it will take time to see. I had a smile from ear to ear driving home tho! Would recommend these plugs by far!
Did the base hobby shop have all the tools you needed? Did you replace the COP boots also? How about the fuel rail? Did you have to pull it to get access to the plugs?
Old Oct 26, 2011 | 12:16 PM
  #37
BL4CK3D0UT's Avatar
Yes they did, you pretty much need a good socket set with lots of extensions and swivel sockets. I would highly recommend replacing the COP boots and use the grease on the boots and plugs too. I don't remember messing with the fuel rail at all... the fuel rail is over the COP boots but you are able to squeeze the COPS by the fuel rail without moving it.
Old Oct 27, 2011 | 01:08 PM
  #38
Norm's Avatar
I got 197K on mine.
I could have gone longer as well but I had a coil go bad so I figured if I was going to spend the time to replace the coils it only made sense to do the plugs as well.
Old Oct 27, 2011 | 01:19 PM
  #39
Bluejay - When I called around for shop estimates, a lot of them said that the 4.6 also had that problem but they are probably wrong. The dealership guy probably didn't know what he was talking about either but hey its the only ford dealer in my town. I'm mostly doing this because they drop down in price over time, claim more power and mpg, and love to modify.
I'm trying to find more information on the plugs and i found a guy with a titan used NGK vs Pulstar on a dyno and the pulstar gave him more horsepower. If you want to take a look, click here: http://www.titantalk.com/forums/tita...o-testing.html
yes there are 4.6's that have the plug breaking problem also but they have the 3v head just like the 5.4......
Old Oct 27, 2011 | 01:23 PM
  #40
jethat's Avatar
I dont think they put the 3v 4.6 in f-150's until after they fixed the plug design in 08. Not positive on that. I know Mustangs got the 3v 4.6 but I'm not sure f-150s did until 08+ when they no longer had the 2 piece plug.
Old Oct 27, 2011 | 01:41 PM
  #41
you're correct........actually f150's didn't get it until the nbs in 09.....what I was referring to is the fact is that at the time some dealerships were afraid to do plug changes on anything and we also know how well informed some of the dealership service writers are.....
In general any Ford vehicle mfg from 04-07 with the 3v head on the 4.6/5.4 will have the broken plug issue...check the cop boots......black is bad and brown is good......
Old Aug 9, 2013 | 12:14 PM
  #42
BL4CK3D0UT's Avatar
I'll be building a turbo setup within the next couple weeks, so ill be replacing the plugs with some Denso Iridium's. I'll post pics of the pulstar plugs when I pull them out, they probably have 25,000 on them.
