TRY THIS: Throttle Calibration for EFI engine.. It works!
Old Dec 22, 2010 | 04:16 PM
  #136
kaboom10's Avatar
Originally Posted by glc
What problem? You don't have VVT, that's only on 3 valve engines.
And that's what I said. No problem but could it be tuned out?
Old Dec 22, 2010 | 08:38 PM
  #137
Can WHAT be tuned out?
Old Dec 31, 2010 | 03:57 AM
  #138
snappylips's Avatar
Not surprised at where this thread has gone.
You need to ignore and roll your eyes when dealing with a guy who thinks an 8.8" rear is stronger than a 9" rear.
SL
Old Jan 1, 2011 | 01:28 AM
  #139
Steve83's Avatar
So you're saying to ignore & roll your eyes at all the Ford engineers?
Old Jan 1, 2011 | 10:08 AM
  #140
Originally Posted by DarkShadowSTX
I did this on Monday and got a little better throttle response. Before I did the process, I set my Gryphon back to stock. I have now been running my custom 87 perf tune and have a whole lot better throttle response.
The only bad thing I'm noticing though is my mileage, according to the Gryphon, has gone down bigtime. Before, I was getting 15 with my 87 perf tune and now I can't get it above 13-13.5 in either stock mode or with the tune. Since its winter, I let my truck warm up for a few minutes before I drive it so my average on the Gryphon goes down to like 8 but I can't get it to reach my normal numbers, and I don't have a lead foot. I will have to check my mileage by hand when I need to fill up but so far its not looking good.
The reason you have better throttle response is you changed tunes, and your truck has to relearn the adaptive strategy.
Old Jan 1, 2011 | 10:43 AM
  #141
DarkShadowSTX's Avatar
I know that. I had better response in stock before I reloaded the tune though.
My mileage is still way worse than before I did this stupid "trick". Hopefully leaving my battery disconnected for a while will get rid of that and I can start fresh again.
Old Jan 30, 2011 | 08:14 PM
  #142
Torque&Recoil's Avatar
Throttle Cal with Power-adjustable Pedals
Checked pedal interference with firewall first - it was just bottoming out on the firewall. Used the switch to power it up a little - no more interference. Pretty sure there was a difference on throttle response as mine was pretty sluggish before. I've been having the failsafe mode problem and still have the check engine light locked in. I'll probably repeat this after going to the dealer in a couple days.
Great guidance and the price is right!
'06 SCrew 5.4L
Old Jan 31, 2011 | 04:02 PM
  #143
DirdyDan's Avatar
Seemed to make a really large difference in our '06 Fusion. I've always hated the car due to lack of throttle response and sluggish and sometimes harsh shifting. After this it drives like it actually has a throttle cable. It shifts so much better. No more leaning forward and waiting for it to go.
And no, none of my sensors are out of wack. I checked it with a scan tool myself when I worked at an auto shop a few months back.
Old Feb 4, 2019 | 09:33 AM
  #144
Sherri Taylor's Avatar
Sensor
Originally Posted by BLACKOUT FX4
The Diamondbird Mod
Not sure if anyone has seen the posts by DRE23 within the "Throttle response 2009+" thread. Member DRE23 posted an interesting method to recalibrate the throttle on EFI engines, Apparently this method has been posted on other forums with great success. I was skeptical at first so I tried it on my Tacoma work truck and to my surprise, It actually made a difference.. So this morning I tried this method on my 2010 FX2 and no BS, It made a big difference in my throttle response, The front end of the truck actually raises up and the tires let loose when i punch the gas pedal. I did some research on other forums about this and the common consensus is that this resets the factory throttle setting and can be put back to factory by disconnecting the battery if need be.
Does anyone know how and why this works and how the heck someone figured this out? It's pretty cool and FREE!
TRY IT!
Throttle calibration can substantially improve throttle responsiveness over "factory standard." Many people notice what appears to be sluggish throttle response or a "dead area" at initial accelerator depression. Throttle calibration can take care of these.
1) turn the key in the ON position (don't start the engine)
2) press the gas pedal down slowly all the way down
3) let go of the gas pedal fast so it come back up
4) turn key into the OFF position
repeat steps 1-4 two more times then start engine.
Most drivers notice an immediate change in throttle response, but depending on your driving style, you may need to repeat this procedure periodically due to the computer's adaptive programming. You likely need to repeat this procedure any time the battery is disconnected.
Thanks to DRE23 & Diamondbird for the info!
hey I had that sensor changed on my truck and now it won't crank. Just spins and spins. Any idea on what it could be?
