Suddenly Running Rough
Old Nov 10, 2010 | 07:35 PM
Seth22's Avatar
I saw in another (2 year old post) about Global Automotive ignition coils. Is this THE Global everyone is talking about: http://stores.ebay.com/GLOBAL-AUTOMOTIVE
Old Nov 11, 2010 | 02:37 AM
Yes it is.
Old Nov 16, 2010 | 10:04 PM
Bigwheel's Avatar
Dagnabit!!!! I cannot get to the bolts holding in the COP on cylinders 7 & 8. I've tried every stinking extension, wobbler and skin I have. Question...for the 7mm socket are you using a 5/8 to 1/4 adapter with wobbler or are you using a 1/4 wobbler with extentions?
Old Nov 16, 2010 | 10:33 PM
jbrew's Avatar
You mean 3/8 to 1/4 ? All 1/4 here. Use a 7mm wrench if you have to. I think I use a socket for all , -and a little battery impact. You better tape your sockets and extensions lol.
Old Nov 16, 2010 | 10:39 PM
Bigwheel's Avatar
You would notice that
jbrew's Avatar
Or you may end up fishing for sockets under the intake. Here's the pole I use -
Old Nov 16, 2010 | 10:41 PM
jbrew's Avatar
Yea, I did right away. Strange ehh?
Old Nov 16, 2010 | 10:45 PM
Bigwheel's Avatar
That just cracked me up. Funny stuff. Yea I've already dropped a couple of tools and had to fish them out but haven't lost a socket yet. I learned the tape thing the hard way a few years ago.
Old Nov 16, 2010 | 10:52 PM
jbrew's Avatar
I did my intake gaskets once and found my old Snap On 1/4" drive ratchet under there. I wondered where that went for along time! Also, miscellaneous sockets surrounding the knock sensor, - like they where planning some kind of attack. 1/2 of a bologna sandwich, - past the stink stage and petrified.
Old Nov 17, 2010 | 08:04 PM
Bigwheel's Avatar
No sandwiches found yet but a couple of varmints crawled out.
Got another question...I got cylinders 4 thru 8 done and now working on 1 thru 4. Any tricks getting to # 4?
Old Nov 17, 2010 | 08:50 PM
jbrew's Avatar
Well, I like lots of room. So I pull the that big plugs out of the way and tir them back bungees. I might have a pic of the tie back somewhere ? I'll look real quick.
Disregard #4 being in #1's spot. I switched coils because my new Motorcraft coils went bad shortly after purchase. I replaced all with Global coils. I never had a Global coil go bad yet.
You can see how I tie those plugs back. Your model is a little different, - you may have more room , but I doubt it, here's a pic -
Old Nov 17, 2010 | 09:09 PM
Bigwheel's Avatar
Got to it so we're good and thanks for the advice. Hey...you know I mentioned a hissing sound earlier in this post? Well I found the source just off of the PCV valve. There's a small hose running to the TB from the pcv and the back side had a whole in it. Pulled that end off and the rubber hose on the other end had a hole. No wonder I'm running lean.
Keep fingers cross as I'm down to the last cylinder (4).
Old Nov 17, 2010 | 09:21 PM
Post #5:
Follow the PCV system all back by the firewall and behind the intake. Reach your hand back there while your hearing the hiss, -right at the intake connection. Move around @ that connection and I bet you find the leak.
jbrew's Avatar
Just make sure the boot seats down correctly on #4. I missed the plug once on that one and the boot folded inside. I probably couldn't do that again if I tried, but it can happen with any of them.
Old Nov 17, 2010 | 09:23 PM
jbrew's Avatar
Originally Posted by glc
Post #5:
