Engine/transmission power...
Old 09-27-2010, 09:26 PM
fishsniper's Avatar
Hi guys, I am looking at both a 1998 5.4L F150 and a 1995 5.0L. I know the 5.4 is a good engine and has a good towing capability. What about the 5.0? Is it a good engine? Does it have good towing capacity? The 5.0 would be paired with a 5 speed, so does that reduce the towing capacity? What are some common problems with both? Thanks in advance!
Old 09-28-2010, 01:43 AM
glc is offline
Compared to the 5.4, the 5.0 is a torqueless wonder, it's a car engine. The 5 speed will also limit your towing to about 3500#, it's a relatively light-duty tranny. They are both very reliable.
Old 09-28-2010, 11:02 AM
Steve83's Avatar
Depends which 5sp - some actually got the ZF, and the tires & gears will have an effect, so you have to read the door sticker codes to know. Then download the owner's manual from Ford to find the towing capacity.
Old 09-28-2010, 11:22 AM
phil6608's Avatar
I had a 93 5.0 and my brother had a 97 4.6 that would out perform the 5.0 in any circumstance!
Phil
Old 09-28-2010, 02:54 PM
glc is offline
Correct, Steve - I was assuming M5OD-R2. Did the ZF ever find its way into a 95 5.0 F-150? I've never seen one.
Old 09-28-2010, 03:15 PM
fishsniper's Avatar
So what I'm hearing is that it is a good engine, but not very powerful. What about the 351? What is your opinion/experience about that one?
Old 09-28-2010, 04:08 PM
glc is offline
The 5.4 is a better tow motor than a 351.
Old 09-28-2010, 04:15 PM
fishsniper's Avatar
Ok. Thanks for your help! So your choice for motors are 1. 5.4, 2. 4.6 then the others?
Old 09-28-2010, 10:42 PM
avfrog's Avatar
^ 5.4 only IMO, or a 2011 6.2!
Old 09-28-2010, 11:27 PM
jethat's Avatar
351 windsors are good motors. They can be beefed up pretty easy stock they have lower torque output then a 5.4 but they have lots of potential and a great aftermarket support 2nd only the the small block chevy. They also can last a long long time if taken care of. If you dont wanta spend money beefing it up the 5.4 is the better motor..
Old 09-29-2010, 01:29 AM
Steve83's Avatar
It's like asking which is the best fighter airplane. It's not the machine - it's the guy controlling it. If you know what you're doing, you can tow with almost anything. I've towed over 10Kip with my 4.9L/NP435/3.08s/32x11.50s. I wasn't doing 90, but do you really want to?
The point is: any engine can tow.
Old 09-29-2010, 06:55 PM
fishsniper's Avatar
Of course I don't want to do 90 while towing, but I do want the confidence to know that I can move it quickly and effectively if I need to and I want to tow as much as I can because I am looking to get a bigger boat, which I know aren't that heavy, but just to know for sure that the truck can handle it.
Quick Reply: Engine/transmission power...
