efan install problem!!
Old Aug 24, 2010 | 02:31 PM
jemckinney's Avatar
I just put in a flexalite e-fan. Got it used for a good price, it came off a chevy so the mounting brackets don't line up but I rigged it up to work. Because it's not for an F150 I didn't have the greatest directions to install.
I got it all wired up and everything and I went to start my truck and the fan didn't trun on! I thought for a second, turned on the AC and the fan kicked in full force. It has the regular flexalite control module. I wired the AC to the gray and white wire, I think that's positive.
What did I do wrong, why will it only work with the AC on? Is it possible that I have a bad accessory wire for when the key is turned on? I won't get to look at it again till tonight, I'll just drive with the AC on for non lol.
Old Aug 24, 2010 | 02:37 PM
MGDfan's Avatar
hey.
I'm not familiar with that controller (there are far better ones out there, BTW - hold that thought ).
Some things are common however:
- what model efan kit is it - and is it a 1 or 2 fan system?
- Where did you place the temp probe?
- What turn-on temp did you set it for - how did you determine that temp (means of measurement)?
............ remember - it's only supposed to run when commanded by the temp threshold - NOT at first-start in a cold truck)
- fuse sizes?
- wiring gauge?
- Pics / diagram / text details of how you connected the thing? E.g. - primary power direct to battery, etc ...)
- BTW - did you bench-test it before install to ensure it was working? Kinda late now, - next time, okay? lol)
- I assume you went to FAL's website for Ford install instructions? (the 'self-help' portion of my diatribe)
Need more info in order to help you ...
MGD
Old Aug 24, 2010 | 03:29 PM
jemckinney's Avatar
mgd, thanks for the quick reply I think I was too impatient. I thought the fan would kick in as soon as the truck was started, everything is working good now. I just drove it, I'm loving the extra horsepower from a dead stop. I hope MPG's go up
Old Aug 24, 2010 | 04:31 PM
BLFX4K's Avatar
Keep us updated on the fans and how they affect mileage, when you stop driving like a maniac with this new found power!
Old Aug 24, 2010 | 05:43 PM
jemckinney's Avatar
Funny you say that, I couldn't believe that doing the fan mod would make my tires chirp when I accelerate from stop. I have 315/70/17 bfg AT's and they never chirp, I do have a vortech supercharger with 8 psi so don't expect just the fan to do this but stock 3.55 gears. I can't wait for the 4.56 gears in a few months, it should be fun!!
I will keep you guys updated I think I've been getting 10 mpg on avearge mixed driving latley with my 6" lift and tires. I am getting my supercharger dyno tuned tomorrow which will lean out my fuel economy because I know it's running rich but I'll keep you posted on how the MPG's are.
