Spark Plugs
Old Apr 20, 2010 | 10:37 PM
LaneVines's Avatar
Spark Plugs
Where exactly is the best place to be to see the spark plugs on my 4.6L engine? Above the engine or under it. Dang if I can see 'em?
My engine may not have them...
All I see above the engine is valve cover. Below it I see manifold. I can't even find plug wires?
Old Apr 20, 2010 | 10:41 PM
You better take it to a mechanic. There are no sparkplug wires. Each plug has it's own coil, called appropriately Coil on Plug. Under each coil is a plug down in the recessed area.
Old Apr 20, 2010 | 10:43 PM
munoxide's Avatar
They are best seen above the motor. And would be above the valve covers. There is no spark plug wires on your truck, its going to be a coil on top of the plug with a round head plugged into a wire harness. Remove the bolt on it and pull it out and the plug is down below there..
Old Apr 20, 2010 | 10:46 PM
LaneVines's Avatar
Thanks Guys.
Fascinating stuff!
My last 4.6L engine (1997 model) had coils and wires up front.
Old Apr 20, 2010 | 11:41 PM
jethat's Avatar
Originally Posted by LaneVines
Thanks Guys.
Fascinating stuff!
your plugs are in the same place as they were on that engine.
Old Apr 20, 2010 | 11:45 PM
f150fella08's Avatar
^ yep..they are right on the inside of the valve covers.
