Fuel line disconnect
Old Apr 20, 2010 | 10:23 PM
munoxide's Avatar
Anyone know how to disconnect the fuel line from the fuel rails on each side? 01 5.4....Thanks.
Old Apr 20, 2010 | 11:39 PM
jethat's Avatar
Its kind of a drag. you get the plastic disconnect tools slide them in push wiggle them and they come off. Auto parts stores sell the kits for about $10
Old Apr 20, 2010 | 11:42 PM
f150fella08's Avatar
agreed. you have to wiggle it and you may have to try for a while..but itll come off
Old Apr 20, 2010 | 11:46 PM
munoxide's Avatar
Is it the same tool to disconnect the lines from the fuel filter?
Old Apr 20, 2010 | 11:49 PM
jethat's Avatar
similar tool depending what one you use. the one I got that worked the best was a HVAC disconnect kit. It a bugger getting them things to disconnect even with the tool.
Old Apr 20, 2010 | 11:54 PM
munoxide's Avatar
The one for the fuel filter that i use is the metal X type with 2 different sizes on each side that clamp down on the line and slide into the line to release it.
Old Apr 20, 2010 | 11:56 PM
jethat's Avatar
that really wont work. you need the really thin plastic one. go to the parts store and get the right tool. Its the only way to get them off.
Old Apr 20, 2010 | 11:59 PM
munoxide's Avatar
Like this one? http://www.partstrain.com/images/pro...otc/OT7370.jpg And does it work the same way as the filter line tool?
Old Apr 21, 2010 | 12:06 AM
jethat's Avatar
yeah kinda like that. The kit I got had several different sizes. Has to fit perfect. And like I said its still a drag. I had one off my new engine to screw around with first and working on it outside on a bench it took awhile. of course it made it easier in the truck because I had it figured out. an ordeal it is..
Old Apr 21, 2010 | 12:10 AM
munoxide's Avatar
I need to pull my intake off which is why im thinking of getting the rails out of the way. Can i just leave them connected to the lines and just unbolt them from the intake?
Old Apr 21, 2010 | 12:13 AM
jethat's Avatar
that would be the best way. You really dont need to take it off to remove the intake.
Old Apr 21, 2010 | 12:26 AM
munoxide's Avatar
Yea, ill just unbolt them from the intake then. Thanks for the help
Old Apr 21, 2010 | 12:55 AM
Toyz's Avatar
I got these from harbor freight about 5 years ago, have used them dozens of times. I think the blue and red is what I used on my 99 5.4. There was like 5 or 6 pieces/sizes in the set for 2.99
Old Apr 21, 2010 | 01:28 AM
munoxide's Avatar
Cool thanks again for the help, appreciate it.
