New Engine Break-In period
Dynotech- I always appreciate your input because it gives us a look at the technical side of engine "hows and why's" as well as forensics that you mention from time to time. I wasn't thinking of towing when I said "work it". I agree with their guidelines concerning when you should be able to tow. I actually was going to post the link that is posted right below your post. I know this was motorcycles but still very valid principal concerning seating rings in and the power produced by properly seated rings. I worked in a Ford dealership back in the mid-late 60's. They had a fair amount of problems with chrome rings not seating (that problem had existed for a quite a while before that) and Ford had to pay to re-ring them. The mechanics didn't want to have a redo of their re-ring so they devised a way to avoid that. They put the piston with the rings in dry ( I realize it got oil splash about the second revolution ) and no water in the radiator. They started it and held the water hose (with press valve) right over the rad opening and revved it repeatedly to about 25-2800 RPM while watching the exhaust. The second they saw the smoke (minor-mod.) disappear they dumped the water to it at idle. They broke it in right in their stall!. They did quite a few re-rings back then (and the warrantee was only 12&12K) and never ever had a complaint about oil consumption on any done that way. I'm sure Ford probably wouldn't have approved of it but it worked.
My break in method for all my engines...
Slightly idle 2-3 minute break in on first start up, unless we are talking OG and need to break in a new cam with flat tappet lifters... Drive a mile at slow speeds listening for noise. Basically getting the engine up to operating temperatures.
Stop the car in the middle of the road, and do a nice smokey burnout launch and drive it like you stole it....
When I picked up my truck, it just had a few miles on it. The dealer asked if I wanted to take it for a test drive before I Signed the papers. I said sure.... When I pulled out on the road, I did a massive burnout then pulled right back into the dealer and said, "I'll take it!" by the next week I had a tuner, cai, magnaflow catback, and nitrous installed.
in this video I did not see any torque plate on this block while honing .... that poor guy will have a distorted block once he gets it back and torques his heads on.
