specific shake/shudder at 40-50 1100-1300 rpm
Old 02-11-2010, 04:01 AM
Phreak's Avatar
nuff said, only happens when there is an incline, not much of an incline is needed either. just starts to shudder i'd say. maybe even go as far as saying it feels like a jolt like trying to shift but refuses. ah i'm no mechanic so what do you all think?
Old 02-11-2010, 04:54 AM
03screwman2wd's Avatar
you got a misfire
Old 02-11-2010, 09:02 AM
Project F150's Avatar
I had the same issue on my 99 4.2L. At about 120k miles, from 1500 to about 1600 rpms, the whole truck would get a shake and it ended up being caused by a bad coil pack.
Old 02-11-2010, 02:32 PM
glc is offline
Which engine ya got? How many miles? What's its exact ignition parts maintenance history?
Old 02-21-2010, 12:47 AM
Phreak's Avatar
5.4, 116k, um, only had the truck since end of July and haven't really had the trucked looked over yet. Only new tires.
Old 02-21-2010, 02:47 AM
glc is offline
Probably needs spark plugs and maybe cops.
Old 02-21-2010, 05:03 PM
Phreak's Avatar
alright, thanks.
Old 02-21-2010, 05:53 PM
fastforward7's Avatar
Manual or automatic?
Old 02-22-2010, 12:25 AM
glc is offline
5.4 in a F-150 is only going to be an automatic.
Old 02-22-2010, 08:54 AM
hockeyfanjeff's Avatar
Yep sounds like a low grade misfire. Is it happening as the truck just shifts into OD? As others have stated, most likely it's a coil over plug going bad.
Old 02-23-2010, 02:39 AM
Phreak's Avatar
Yeah probably. Honestly haven't a clue what the shifting into OD happens.
Old 02-24-2010, 12:35 PM
F150man21's Avatar
just make sure that you use MotorCraft spark plugs, other plugs wont last long and might come apart making a big mess
Old 02-24-2010, 01:23 PM
Phreak's Avatar
okay. I've already begun doing that. Going to attempt it myself. Then go somewhere if I get in over my head.
Quick Reply: specific shake/shudder at 40-50 1100-1300 rpm
