codes that wont go away!
1998 F150 supercrew 4.6 4x4
keep getting the same 3 codes
Exhaust gas recirculation flow insufficient
system too lean bank 1
system too lean bank 2
I have changed the EGR Valve EGR tube and the 2 high temp silicone hoses going to the dpfe sensor and a brand new dpfe sensor nothing has changed also cleaned the MAF meter, and did a BG fuel injection service as well as the BG egr service and still nothing anyone else have a thought on this?
yea what he said... mine was 100 percent clogged up and it will throw those same codes jus make sure that u pull the entire upper plenum off because you dont want all that crap goin down into ur intake
I had the lean bank 2 on my 98 f150 4.6 and it ended up being that I had a dead cylinder. Is the truck really boggy on the bottom end? Run a compression test if it is. Changing those engines is a pain but it can be done with out taking the intake manifold off, like the book tells you to do.
Good luck
Good luck
