trick flow heads top end kit.
Old Jan 30, 2010 | 10:15 AM
BLUE20004X4's Avatar
Hum.... this looks like a nice kit. I gotta (gotta?) ok want to do an engine swap for a built engine sometime this year. This might be the way to go. I want to find out more now, good find OP!!!
Old Feb 13, 2010 | 07:36 AM
JimmysotherFORD's Avatar
ok so i'm thinkin since money's tight this might be the better route then a prochager since that will cost me close to $6000 all in all. i have a 4.6L what all is needed to make this work i have a very good idea but need more and specifics, some info on my future plans....
in the near future
built 5.4L block
procharger d1sc
what all will i need i know maf and injectors, but will 42# be overkill, i plan on going boosted later so i'd rather buy the 1 set now then 2 in the long run. also would a torque converter upgrade be a good idea, i know the stock one is only good to like 5400rpms.
as always any insight is greatly appreciated thanks
Old Feb 16, 2010 | 10:33 PM
lilthmp81's Avatar
with the possible amount of power this whole set up could produce, what kind of mods need to be done to the tranny? Would just a stall converter suffice? Say a 1400 or 1600 stall. (for a 4r70w) ok i'm an idiot and didn't see the previous post now i can't delete this one
Old Feb 17, 2010 | 05:41 AM
Veteran: Army
you would want a valve body or seperator plate kit as well
Old Feb 17, 2010 | 10:48 AM
JMC's Avatar
JMC
25 Year Member
First thing I checked was the valve guides. Powdered metal. No thanks!
