2005 Cam Phaser problems
Champion 7989 two piece, porcilin and one piece metal ground nut, the oil was cooler with the 160 thermostat so the phaser's were locked out and the truck ran better. I would have taken the motor to the ford dealer to pull the stuck plugs but the end of the insulator was in one. You get any procilin into the cly and it will wreck that hole. I am changing the phaser's on the older motor, got the driver side done, took out the wheel well linner on the pass side to get to the last cover bolt and the trany dip tube bolt. Lifted the cover pulled off the phaser and found it has been replaced before, then it gets ugly. Chain guide is broken, just about ready to remove timming cover as soon as I figure out how to get the last power steer pump bolt out, it will be a good time to check if the cams were timed right.
motor is quiet, had to put the vac line back on i pulled it off removing the left valve cover, fixed that today. all is quiet just injector noise. if i was'nt so cheep or won the loto i would have the ford dealer do the repairs and keep the skin on my hands.
Cam Phasers
I'm having the exact same problem as you were having .Any advise you can give before I start my tear down would be greatly appreciated ,Thanks
310000 kms still ran great, 1 quart oil for 10000kms.
got two more jobs, putting on 7000kms to 10000kms a month so I sold the 05 FX4 and bought a new 10 FX4, great truck, do not really like anti spin or the abs brakes that come on when turning corners on the ice.
But this seams to be the future of the truck driving you not you driving the truck.
