05 5.4 engine running to hot
Old Jan 18, 2010 | 06:32 PM
jasonh007's Avatar
My 2005 5.4 enine temp is running between 220-230 degrees and i am wondering if anyone knows what may cause it to start running hotter then normal? I have a edge evolution and its just been the past couple weeks my alarm will sound when i hit 230 degrees. Maybe im just being paranoid but Can anyone shed some light on what temp. i should be running and how to fix it?
Thanks!
Old Jan 18, 2010 | 06:37 PM
jethat's Avatar
Should be about 198-202 range. I'd start with the thermostat might be stuck..
Old Jan 19, 2010 | 07:28 AM
MGDfan's Avatar
I'd start with a coolant level check - it's easier
Is the cooling fan engaging?
Any hoses collapsing?
Last time you serviced/flushed/replaced the coolant?
