Build project 5.4
Old Dec 27, 2009 | 12:11 PM
  #61
built54's Avatar
Originally Posted by shifty_85
Hey built what are you running for a heat exchanger on yours buddy?
Im using a big aluminum h/e behind my front bumper. I forget who makes it but an afco wouldnt fit with my bumper brackets so im using some knock off brand but its the same thing just not name brand, so 1/4 the cost.
Old Jan 12, 2010 | 05:07 PM
  #62
shifty_85's Avatar
ok guys i snaped a few pictures.... this motor still has cross hatching in the cyl. walls doesnt that mean its really low mileage??? ill snap more close ups. Also i have 4.6L heads will the valves out of the 94 4.6L work on the 99 5.4? the valves are the same size right??
motor spins VERY easy i stood it on the fly well and could spin the motor around with very lil effort.
im trying to deside if i want to do cams and a blower or one or the other? i found a blower with most the stuff i need for 400. found cams any were from 500-1200 a cam set that was 625. went from 1,000 RPM to 5,600RPM i think i might run that. ill try and find the link again.
blurry pic
alot better pic
need upper and lower intake. Also other than honing and cleaning the cyl walls and getting new bearings, and oil pump. anything else low end in the block i need to do?? Aftermarket pistons or is there no need??
Old Jan 12, 2010 | 06:30 PM
  #63
Neal's Avatar
Cool
HI!... Well if your going with a blower then scrap the stock rods and pistons. That "99" should have a forged steel crank in it. Check the parting line on the crank. Get ARP main and head studs if your going to SC it. A D.S.S girdle wouldn't hurt either while you got it apart. Get good head gaskets, like the MLS Cometic or Felpro. new timing chains, guides etc. Brass frost plugs are good. A Cobra high volume oil pump is cheap in price or you can run a Melling or MMS racing pump.
Old Jan 12, 2010 | 07:52 PM
  #64
phil6608's Avatar
Yeah,
what Neil said.
Phil
Old Jan 12, 2010 | 10:14 PM
  #65
built54's Avatar
main/rod bearings, but id say go with new pistons and rods. id go .020 over too so you know all your cylinders are good.
Old Jan 13, 2010 | 03:03 PM
  #66
shifty_85's Avatar
thanks for the info guys. ok a local shop around here does head work. cleaning and valve job 110 for a pair of heads. then its 40 PER head for resurfacing. not to bad 190 total and i know my heads are good and lvl. i didnt ask about prot and polishing is that even worth it????
i heard somewere a set of NON-PI heads that get ported can out flow the PI heads?? so what happens if you port PI heads???
just some odd ball questions hoping yall can help me with. should i build this motor part by part or find an entire rebuild kit for a grand or so??
also i am going to put a block heater on this motor were should i put it??
Also my buddy took 3-4 valves out of one of my heads can i use the valves out of my 94 4.6L Non-PI heads in the basement? or should i buy a new set of valves?
Old Jan 13, 2010 | 03:30 PM
  #67
Klitch's Avatar
why mix n match valves on a "fresh" motor?
Old Jan 14, 2010 | 03:50 AM
  #68
shifty_85's Avatar
my buddys 03 PI motor had a bent valve from the start so he took one from mine. and then in timing it bent another 1 and broke another one. the deal to get our motors was he could take any parts needed to make his truck run.
so i am missing 3 valves out of one head. will the 94 non PI valves work??
Old Jan 14, 2010 | 07:14 AM
  #69
phil6608's Avatar
Yes. porting the heads is a good idea. You will see more power.
[QOUTE=shifty_85;4041109]just some odd ball questions hoping yall can help me with. should i build this motor part by part or find an entire rebuild kit for a grand or so??[/QUOTE]
Don't take this the wrong way,,but you should buy a built short block from a professional builder!!!!
Have you ever built a mod motor?
After the head story,,,I would definitely have a pro do it.
I agree with klitch,
why mix and match? Put ALL new parts in your heads.
Your building a NEW motor. Everything should be NEW.
Phil
Old Jan 14, 2010 | 01:23 PM
  #70
Klitch's Avatar
I still dont understand why he's even considering it... New valves arent overly pricey, neither is guides.
Old Jan 14, 2010 | 06:36 PM
  #71
shifty_85's Avatar
ive only look for valves for a short time on Ebay and what not and the really top of the line stainless steel ones scared me..600 bucks for 16 valves??...really? but OEM replacements were%2
Old Jan 21, 2010 | 11:25 AM
  #72
shifty_85's Avatar
ok guys i found an inline pump. that can do 80 -130 Gallons per hour would that be enogh to keep up with the set up i want?
Old Jan 21, 2010 | 03:09 PM
  #73
JMC's Avatar
JMC
25 Year Member
80 Us gallons is about 303 liters. and 120 US gallons is about 454 liters.
Old Jan 21, 2010 | 07:13 PM
  #74
shifty_85's Avatar
lol thanks for the convertion. does that sound like it will flow the fuel i need to my superccharged camed 5.4?
Old Jan 21, 2010 | 07:40 PM
  #75
Klitch's Avatar
uhm yeah... 255lph is good enough for 42# injectors...
