Build project 5.4
Old Dec 25, 2009 | 02:00 AM
  #46
Klitch's Avatar
hmm, I think your aiming more for a larger heat exchanger, not a inner cooler. That would be a no since the diesels run air to air heat exchangers, and i dont think they even run an inner cooler so to speak.
If you want better IAT drops, look into a large heat exchanger or radiator and make your own mounts for it.
Old Dec 25, 2009 | 02:05 AM
  #47
shifty_85's Avatar
yeah sorry used to workin on turbo diesels. but is it worth the time and effort to put another cooler up behide the grille? or is the one in the supercharger just fine?
Old Dec 25, 2009 | 03:07 AM
  #48
Veteran: Army
Originally Posted by shifty_85
so buying the whole upper lower S/C and injectors for 1,100 is cheaper than buying the S/C and upper for 400. then finding lower and buying my own injectors?
there's 95% complete setup in the classifieds for around a grand, nonwoven is trying to sell it...
Old Dec 25, 2009 | 03:10 AM
  #49
Veteran: Army
turbo's and majority of centrufigals use an air to air intercooler
majority of positive displacement superchargers use a water to air, and yes if you go the lightning swap route then either an upgraded heat exchanger (the one under the grill) or a Killer Chiller is recomended...
Old Dec 25, 2009 | 11:36 AM
  #50
shifty_85's Avatar
you got a link tararjerame to the S/C parts?
Ill have to look into that heat exchanger as well.
Hey built what are you running for a heat exchanger on yours buddy?
Old Dec 26, 2009 | 03:30 AM
  #51
phil6608's Avatar
Here's one. https://www.f150online.com/forums/su...swap-sale.html
I think the one Stoffer is talking about,the guy(John) is putting it on his truck.
Most guys run an Avco H/E. It's an upgrade from the stock one.
http://www.johnnylightningperf.com/s...176&cPath=2_13
You may find it cheaper,,,,so shop around.
Phil
Old Dec 26, 2009 | 04:18 AM
  #52
Faster150's Avatar
Originally Posted by Klitch
for the window your looking at, the XE270AH's like mine are suppose to be for low-mid range. but note that lowered my vacuum at idle.
those also have more than 10 degree of overlap meaning you loose boost with them. i got rid of mine and got blower cams just for that reason
Old Dec 26, 2009 | 04:21 AM
  #53
Veteran: Army
i forgot about that one, I PM'd him another link and yeah I'm pretty sure John is gonna run his kit now
  #54
Faster150's Avatar
if your looking to make in the 600hp range.. stick with the stock cast 5.4 crank if that is what is in the engine you are getting. no use in dropping money on a heavier forged crank if your not going to be making enough power to break the stock one. less weight means the engine will spin up faster and get to the power quicker. get a nice set of I or H beam rods. Ross or Manley/Eagle pistons. ive seen too many broken mahle pistons. ie Neal, Built, and Boss all cracked their mahle pistons.
Old Dec 26, 2009 | 10:17 AM
  #55
150xlt's Avatar
I am pretty sure most of the early 5.4's had forged cranks and a few of the later oned did too. You really cant go wrong with any of the aftermarket h/e's, I have yet hear of anyone complaining about a certain brand. For rods, pistons, ect the cheapest place i have found is paschalperformance and jlp after that. I had a local machine shop tell me that he orders all his 5.4 stuff through jl because he is selling it cheaper than he can buy it. Then i was playing on paschal's website and seen their prices are even lower than jl's.
http://paschalperformance.com/partsSupplies.php
http://johnnylightningperf.com/shop/...php?cPath=2_14
Old Dec 26, 2009 | 10:33 AM
  #56
Neal's Avatar
Cool
HI!... Just a correction. I never broke/cracked any MAHLE pistons. I had 3 get damaged when several pieces of broken cast valve guides got sucked into the engine. That was FOX LAKE's fault.
Old Dec 26, 2009 | 10:36 AM
  #57
150xlt's Avatar
what ever happened to your truck you wa building?
Old Dec 26, 2009 | 10:39 AM
  #58
Neal's Avatar
Cool
HI!... It's sitting in my garage. Slowly gathering parts. I started building up something else........... a house much more expensive!
Old Dec 26, 2009 | 12:38 PM
  #59
Klitch's Avatar
not enough for me to notice on the gauge. i still see 10psi when i pinch it.
Old Dec 27, 2009 | 12:10 PM
  #60
built54's Avatar
I broke 3 ring lands on mahles, and another engine I rebuilt for someone had mahles and it had 4 broken mahles...
