Clutch Fan Removal Special Tool ?
Old Dec 24, 2009 | 11:47 AM
Steve83's Avatar
I've never seen a t'stat fail open, but I know it can happen. But since we're brainstorming, I'd look at coolant level, & check for debris in the heater core blocking it up. Both in the coolant & in the airstream.
Old Dec 25, 2009 | 09:06 PM
bbarber275's Avatar
Well finally got time to take the water pump off, as soon as I locate my camera will take pictures.I flipped the pump over and there was only one fin left on the pump, and that one I ended up just breaking it off with my fingers.So I am going to take the garden hose on really flush the block and everything out before I put it back together.
Old Dec 25, 2009 | 09:12 PM
f150fella08's Avatar
hmm..is it just that old or did you add the wrong antifreeze?
Old Dec 26, 2009 | 12:36 PM
bbarber275's Avatar
I am guessing old, as I only use Prestone Regular Antifreeze in the truck.I have put around 50,000 miles on the truck since I owned it.Did not see a Motor Craft Logo on the waterpump, so not sure if it has ever been replaced.Here is a couple pictures of the old and new pump.So far I have have 2 of the 8 missing fins.The fins and the plate seemed pretty thinnly made.
Old Dec 26, 2009 | 01:52 PM
jbrew's Avatar
Is that how they come off, I thought you take them off like this -
Old Dec 26, 2009 | 02:06 PM
vegasmoxie's Avatar
There are a couple real slick tools available for that stubborn nut. One of them is designed to be used with an air hammer. It's not a chisel, the bit has a fitted end that goes on the wrench head. As long as you're driving it counter-clockwise it comes off pretty quick and easy.
Old Dec 26, 2009 | 02:48 PM
JMC's Avatar
JMC
25 Year Member
Nice one jbrew.
Regards
Jean Marc Chartier
Old Dec 26, 2009 | 03:01 PM
jbrew's Avatar
- Well, it all went into the trash anyway. Yea try getting that pulley after removing it like that, -without acetylene or plasma. The pulley was all I needed -it was a tricky lol.
Old Dec 26, 2009 | 03:09 PM
Old Dec 26, 2009 | 03:38 PM
jbrew's Avatar
Originally Posted by f150fella08
Yea, it was giving me a hard time, trying to remove correctly. - Temporary insanity
Old Dec 26, 2009 | 03:41 PM
so you just took the whole damn thing off?
Old Dec 26, 2009 | 03:47 PM
jbrew's Avatar
Yea, just pulled the pump bolts. I was in the process of installing ALL new pulleys/ clutch fan/ Think a Powerdyne fan blade. Not sure what blade kit I had. Works great tho. That came from ONELOWF. It was so cold when I did this, the fan shroud fell off the bench and broke in two lol, think JMC sent me a used one , NO WAIT, I ended up buying a new one for some reason..Think I already had it ordered or something.
Old Dec 26, 2009 | 03:55 PM
ah ok..howd that work..seems like it may be a little frustrating with the fan still on..
theres only 4 bolts on these water pumps? all the other ones ive done have had 8 or so..jeep v6'ers and 4.8-5.3-6.0 chevrolets
Old Dec 26, 2009 | 04:11 PM
jbrew's Avatar
Iduno, pretty sure there's 4. I think I crushed the WP propeller in a big vice and spun the fan off, it took a little persuasion from what I remember, it was locked on there pretty tight lol.
Funny, when you spin a new one on, torque specs aren't really that much. I found a new factory Motorcraft clutch fan on ebay, still in the box. $30
Old Dec 26, 2009 | 04:14 PM
lookin at his water pump theres only 4...
wow 30 bucks..thats pretty darn cheap eh? $55+ on rockauto
