built 4.6L!!!
Old Dec 1, 2009 | 04:27 AM
Veteran: Army
you need to remember that under boost intakes act differently
FYI faster150 is building a 4.6, well he's been collecting parts for around 4-5 years now
Old Dec 1, 2009 | 09:55 AM
BlackFord123's Avatar
Originally Posted by derrick929
To be honest, if you want to do it cheap, I'd go with a MMR shortblock...they go for about $2,900 if I remember right. I honestly have no clue how they build them that cheap. You'll end up with more than that in parts and machine work most likely.
If your not looking for the satisfaction of building each piece yourself, I'd go with their shortblocks, save your money and spend it on the other parts. They are tough too, there are a lot of them around, and I've not heard of one single issue.
My grandpa has an aluminum short block sittin in his garage.... think he said it was originally like $3500 is that the block that ur talkin about? an aluminum 4.6L?
Old Dec 1, 2009 | 09:56 AM
Originally Posted by FRod
I should say i NEED to but i don't want to mess it up. Im kind of looking for someone thats experienced in the matter to do it for me? If ya know anyone?
thumperperformance.com
he's does an absolute amazing job in port and polishing just give him a ring or email
Old Dec 1, 2009 | 09:57 AM
Originally Posted by Gotts2BMe
I did not feel comfortable taking my stock TB to more than 69.5mm in diameter. You will NEVER get 75 out of a stock TB.
Also to the OP you will not be able to delete the upstream o2 sensors.
why can i not delete the 02 sensors? im not talkin about just getting rid of them im talkin about totally removing the code for it in the PCM and everything
Old Dec 1, 2009 | 12:09 PM
Veteran: Army
so how is the truck going to run if can't tell what's going on??? the rears can be turned off in the tune but I've never heard of the fronts
but 'eh it's your truck and your idea so have at it, just make sure you film the first start blown motor video's get lots of hits on you tube and street fire
Old Dec 1, 2009 | 02:40 PM
Matts ford's Avatar
as tarajerame said you can delete the rear o2's with a tune but you cant do the fronts since they are the ones the pcm uses to mess with the a/f ratio
Old Dec 1, 2009 | 10:36 PM
ok fine then..... ill leave em
