built 4.6L!!!
Old Nov 30, 2009 | 08:20 PM
BlackFord123's Avatar
Talking built 4.6L!!!
Ok guys i think that this is going to be my project for the next couple of years until im graduated.... here is my idea let me know what you think!
buy another 4.6L for super cheap (200-300 bucks)
refurbish and P&P the PI heads that i have already
find a PI truck intake and install it
75 mm throttle body
forged crank, rods, and pistons
comp cams XE274 stage 2 cams ( possibly)
comp cams beehive valve springs
longtube headers (egr and o2 sensor delete)
3000 stall converter
t-67 sts turbo
electric fans
tuned by HP Performance
I know most of yall are sayin why dont you get a 5.4? because I want it to be a 4.6l powerhouse!
Old Nov 30, 2009 | 08:26 PM
Fordfanatic101's Avatar
Do it Show all the 5.4's up
Old Nov 30, 2009 | 09:43 PM
FRod's Avatar
Nothing is going to be cheap in this project. And if you do come through with it, don't waist your time with the 4.6. The 5.4s have a longer stroke same bore but bigger displacement**, same block and their output is better with higher RPMs. There are sooo many guys with built engines on this forum its unreal and im sure they will tell you the same. 4.6s are for mustangs IMO. 2nd, overall it would be cheaper just to find a 4.6 or 5.4 someones selling on craigslist complete, with PI heads and PI intake, and swap it with your old harness and setup. I highly prefer a 1999 5.4, it has PI heads and an aluminum PI intake that you can port, 2000-2003 come with PLASTIC intakes like mine, in which im swapping out with aluminum so i can port it aswell as the tb and plenum. Aftermarket TBs are overrated, you can get them ported to 75mm+ by someone, or do it yourself, theres help here with that too! There are crap tons of information about how to do the 4.6 to 5.4 swap. Just a suggestion man, other than that we would definitally love to see this! 4.6 OR 5.4!
Old Nov 30, 2009 | 09:45 PM
it was only a matter of time
Old Nov 30, 2009 | 09:49 PM
you gonna port the PI intake?
Old Nov 30, 2009 | 09:56 PM
lol aint that the truth....
yall may believe me or not but my grandpa built the heads for the first ever twin turbo ford gt here in jacksonville.... well things got complicated and under 22#s of boost the engine gave away.... funny thing is the bottom end of the motor was completely stock and the car made 1453 hp! heres the link www.turbofordgt.com/ all it did was bend the nose of the crank lol! well long story short the motor was given my grandpa and is now just sittin in the shop.... i could do a 5.4 i guess!
Old Nov 30, 2009 | 09:57 PM
yea the PI truck intake
Old Nov 30, 2009 | 09:58 PM
a built 4.6 would be something different though don't follow the masses
Old Nov 30, 2009 | 10:01 PM
haha i think asw long as i can get about 550 to the wheels ill be fine with a 4.6..... anymore ill just buy a cobra later on in life
Old Nov 30, 2009 | 11:30 PM
f150fella08's Avatar
do it!!!! id love to build my 4.6 but dont have the money to!
Old Nov 30, 2009 | 11:41 PM
derrick929's Avatar
To be honest, if you want to do it cheap, I'd go with a MMR shortblock...they go for about $2,900 if I remember right. I honestly have no clue how they build them that cheap. You'll end up with more than that in parts and machine work most likely.
If your not looking for the satisfaction of building each piece yourself, I'd go with their shortblocks, save your money and spend it on the other parts. They are tough too, there are a lot of them around, and I've not heard of one single issue.
Old Dec 1, 2009 | 12:00 AM
FRod's Avatar
I should say i NEED to but i don't want to mess it up. Im kind of looking for someone thats experienced in the matter to do it for me? If ya know anyone?
Old Dec 1, 2009 | 01:17 AM
ONELOWF's Avatar
Good luck with that. I ported and polished a 4.6 intake. I had about twenty five hours into it.
Old Dec 1, 2009 | 02:44 AM
Gotts2BMe's Avatar
I did not feel comfortable taking my stock TB to more than 69.5mm in diameter. You will NEVER get 75 out of a stock TB.
Also to the OP you will not be able to delete the upstream o2 sensors.
Old Dec 1, 2009 | 03:11 AM
five0merc's Avatar
Thats awesome. I plan on building mine when it decides to go. But that will be while cause its still going strong at 182xxx. Good luck with the build
