PI heads
Old Nov 14, 2009 | 02:38 PM
jbrew's Avatar
Originally Posted by 4.6 Punisher
I'd go for it. A N/PI engine with PI head will make more power than a regular PI engine, due to increased compression. Make sense?
Exactly. Higher compression w/high octane that burns slower = more power and torque. Does that make sense ?? Hell no, is it true ? Sure is..
Higher compression + More flow. You'll want to top that off with an intake and exhaust (she has to breath) and of course a custom tune. The 4six with the shorter stroke wynds up quicker than the 5four, so you'll have improvements down low , but more up top.
Old Nov 15, 2009 | 12:51 AM
offroadn'98's Avatar
So for what i need...which do you think that it would be easier/cost efficient? I have the means to do the 99+ 5four swap at no cost other than the price of the motor&tranny/ecu/intake... Or i could do the pi swap/intake/gears...with this could i do what i need it to do? I got a while to think about it but i def want more low end. Which would i be happier with...pullin power wise?
Old Nov 15, 2009 | 03:36 AM
jbrew's Avatar
The 5.4L for what you want. You can build a 4six to compete with the 5fours low end , but why ? When you can start with a 5four ?
As the saying goes - "There's no replacement for displacement"
Old Nov 15, 2009 | 04:02 AM
Hell yeah! Thats really what i wanted to hear...
bump
Old Nov 15, 2009 | 07:33 PM
Alright thanks man...yeah i want to start with the 99+ 5four! I have time to think about it just gotta start planning.......but right now im going 5four!
Unless i come across a 6.2l!!!
Old Nov 15, 2009 | 08:47 PM
f150fella08's Avatar
thats not ALWAYS true sir
Old Nov 15, 2009 | 08:54 PM
What makes you say?
More cubes always makes more power.
Old Nov 15, 2009 | 08:59 PM
Originally Posted by offroadn'98
What makes you say?
sure about that mister?
Old Nov 15, 2009 | 09:03 PM
pretty sure sir....UNLESS..................you got forced induction.
In which case you can do the same to a bigger motor and thats all she wrote. right?
Old Nov 15, 2009 | 09:11 PM
according to wikipedia
5.4 3v has 310 HP and 360 TQ
GM 6.0 is 300HP and 360 TQ
dodge 4.7 is 310HP and 330 Tq
Hemi 390 HP and 407Tq
Old Nov 15, 2009 | 09:18 PM
tundra 4.6 310hp and 327 tq
5.7 381hp and 401 tq
titan 5.6 317 hp 385 tq
Old Nov 15, 2009 | 09:35 PM
diff companies have their cars tuned diff i guess...
ford hasn't really won'ted/been able to compete power wise or they wouldn't have switched to modular motors. Pushrods are better for making powr than the modular too.
Now what are they doing to compete with the power outputs of other companies.?.....
their coming out with the 6.2...(increased displacement).
You take two motors...build the **** out of them both.....i'd dare to say the one with more displacement will come out on top and it'll be cheaper to get there too.
Why don't drag cars use 4 cylinders?
Old Nov 15, 2009 | 11:23 PM
jbrew's Avatar
Well , - I'm sure about most everything lol, -but I wasn't referring to those knock-offs mentioned above. That's a little different, the saying there is - "If you own one, plan on replacing it".. - Or something really smart like that.
Old Nov 15, 2009 | 11:37 PM
Nontheless...im still torn between the two.....i'm leaning 5four tho...Like i said i got time to think about it......thanks for the insight tho
Old Nov 16, 2009 | 03:13 AM
jbrew's Avatar
The 99 has the best OEM set up from the factory, - The 99 sports an Aluminum PI intake. You won't find that on any other model from 97 - 03. Not stock anyway. 99 was the ONLY year Ford used it and this was only used on the F150's w/5.4L's that year.
The plastic intakes had some problems with cracking, - ALL V8 intakes have forward water jacket problems/ - gasket issues, but it takes quite a few miles to become evident. Like 120,000 +. - That's if you maintain properly, if not , problems come sooner and more of them.
I wouldn't mind a 99 on the stand to go thru. I'd leave the heads alone if there's no leaks. If there's leaks on that one, - it's a pretty good sign it's been beat/neglected, - but a compression test will tell the story . - Definitely do something with the OEM manifold studs while it's on the stand.
Make sure you go over JMC's swap notes in the "How to" - That will give you a quick education. - Most likely answer allot of questions that come up.
BTW - Add 4.10's to that and the power bug takes control, you'll always want more, - broom the wife/ auction the kids,-- That may get you a SC quicker. Well , if your kids are worth a shmitz
