Please. Help me find my drain plug!
The drain plug may be wither a bolt or an allen screw. It is between the last frost plug and the bottom of the block. Here is a pic on one in another thread. https://www.f150online.com/forums/li...rain-plug.html
there is no way in hell i would hack up my heater hoses to install that garbage when there is other ways to do it...just my opinion.
Has anyone ever had trouble loosening the plastic radiator drain? On my 2002 screw w/4.6L I barely tried to loosen the plastic drain screw and it broke off? I have changed the coolant 3 other times but had an issue this time> Any ideas guys?
When that happeneds you need to remove it with the correct size allen wrench. It works! I ordered a couple new ones from Rock Auto, but an allen wrench will remove the broken one.
